12-16-2015, 05:44 PM | #23 |
Rep 397
In case you do need a new engine I found this for you! Only 100 miles on the engine!
http://www.ebay.com/itm/2015-BMW-M23...tV8FMS&vxp=mtr |
12-16-2015, 07:11 PM | #24 | |
Rep 3,331
Current: '20 X5, '18 M3 ZCP
12-16-2015, 07:21 PM | #25 |
Rep 3,256
12-16-2015, 07:48 PM | #26 | |
Rep 248
I would have thought Porsche would have had oil surge sorted. |
12-16-2015, 08:03 PM | #27 | |
Rep 957
Best was the engine builder in the trailer came out screaming more expletives than a trucker who had been ripped off by a hooker. Apperantly vintage 911 rsr race car parts are pretty hard to come by. No Porsche has nothing figured out, 3 of my friends have the 991 gt3, two are on there 3rd motor under warranty. As for the op just ask them for a screen shot of the max rpm. Should give the max rpm and mileage it occurred. Maximum RPM Achieved is under service functions -> engine -> data -> RPM Limit. That will tell you everything in ISTA. ________ |
12-16-2015, 08:06 PM | #28 | |
Rep 957
That's actually a very good price, odds of finding a 100 mile motor is pretty slim. I would grab that for sure if i was the op. |
12-17-2015, 09:52 PM | #30 | |
Lucky13
212
Rep 1,762
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
12-20-2015, 10:32 AM | #32 | |
Rep 2,067
Maybe he found one - and was told he had the right to remain silent..
2019 X2
12-21-2015, 08:23 AM | #33 |
Rep 860
real good point! Or his attorney advised him not to post here anymore, at last for now. BMW does monitor these forums.
12-21-2015, 08:30 PM | #34 |
Rep 721
12-22-2015, 05:26 AM | #36 |
Rep 5,577
I'm also curious what happens mechanically when an engine lets go from too high rpm.
Someone said piston : valve contact, but it that true. Valve float won't cause piston : valve damage. I've read valve spring breakage is a possibility from too high rpm. Pulling the bolts from the crank end if the piston rods. Then bearing destruction from not being able to handle oil at too high rpm. I guess anything that rotates or moves that wasn't designed to activate at the extreme speed can break, but the failures that destroy an engine from over revving an engine, is it usually lubrication failure or bolt failure ? |
12-22-2015, 08:19 AM | #37 | |
Rep 2,067
Google "Youtube money shift" and you see and hear lots of examples.
2019 X2
12-22-2015, 09:41 AM | #38 | |
Rep 3,331
There are a lot of things that can go, it's more a mechanical failure issue than anything else. The main problem is: -You will not know what is damaged until you do a full engine teardown (which is expensive). -Even if things "Look" ok, there is no way of telling if they've been mechanically stressed, hairline fractured or damaged in a way thats invisible, so you really need to replace the motor. Even if you could replace the pistons and head there is no way to guarantee the motor won't go a few hundred miles later.
12-30-2015, 10:41 AM | #40 |
Rep 264
Other than a horribly gone wrong down-shift, can you even over-rev cars these days? Thought the car's cpu would limit it?
Current: 2019 X3 M40i and 2018 330i
Previously: 2016 M235i Convertible and 2016 X4 28i and many non-BMWs |
12-30-2015, 12:22 PM | #41 | |
Rep 886
With everything running through the computer these days, missing a downshift on a manual car is about the only way to do it. I don't believe there's any way to do it if you have an automatic.
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 01-13-2016 at 04:22 PM.. |
01-13-2016, 04:03 PM | #42 |
Rep 290
01-31-2016, 02:25 PM | #43 |
Rep 195
You cannot slanderously use someone's driving habits against them for a warranty repair. There is no proof that the car itself didn't over-rev given the amount of BS and worthless engineering the Germans throw into these vehicles, which is ultimately the reason for their failures. Hell will freeze over before I lease an Ultimate Driving Machine and be told an engine failure was the result of my driving habits. This is 2016, not the '70s. Get it together. I melted my transfer box stuck in 16 inches of snow in an alley during the dead of winter. The transfer box did not fail because I had my foot on the accelerator for 4 hours straight. It failed because the fail-safes on the car did not activate and put the car into limp mode to prevent overheating. Also, BMW still continues to make parts of the xDrive system out of plastic because they are cheap. They knew better than to ever, EVER suggest that it was because of my driving that I could not get out of the snow in my AWD f30. I bought xDrive for a reason, and they knew they wouldn't have my business if I was charged even a cent. No one drives these vehicles to be light footed.
01-31-2016, 03:25 PM | #44 | |
Rep 3,256
Reminds me of the Nissan GT-R and their transmission. Use launch control a few times and you blow your transmission. They denied claims because it was "abuse". Nevermind the fact the only way to get their claimed 0-60 was to use launch control.
