02-26-2015, 07:18 PM | #1 |
Rep 4,203
P3Cars vent gauge, Stage 1 and accurate boost reading
Well I wanted accurate boost since I have the Stage 1 piggy back tune and not the info from the DME and since the P3Cars vent gauge has that capability I went for it. Got it hooked up per the instructions, t-tap into the brown wire coming out of the small MAP plug and ran it to the blue wire coming out of the P3Cars harness. I set the config to CAR.7 and BST.P per the instructions that came with the wire in the kit which I verified with a tech at P3Cars......well I had a small struggle and Mike at 54 tuning and Rick at P3Cars helped figure it out... Do not use the blue T-Tap in the picture...it is too large. You must use "red" Works great! Thanks guys
All you guys with a Stage 1 need to do this Last edited by horsepower_and_hounds; 03-09-2015 at 09:11 PM.. |
