BMW 3-Series (E90 E92) Forum
Windshield washer not working
05-09-2024, 10:20 PM | #1 |
Rep 2
I own a 2005 E90 320i. A few days ago, a yellow warning light appeared on my dashboard. Initially, I suspected it was indicating low washer fluid. after few days washer stop working ,When I pulled the lever, there was no response no fluid discharged, and even the wipers remained inactive ( NB: wipers working when i up or down the lever) At first, I speculated that a safety feature might have deactivated the system due to the fluid being empty. However, after refilling the fluid, the warning light disappeared, but the problem persisted."
i check the fuses and relay everythings looks good last 7 VIN digits : KP95239 |
05-10-2024, 02:19 AM | #2 | |
Rep 6
05-10-2024, 08:07 PM | #3 |
Rep 3,929
Drives: 330i, 135i
Yeah most likely a bad washer pump. Ireplaced mine as these pumps leak from the bottom nipple. I replaced mine and still have a leak somewhere. Too lazy to gey down there again. 😝
Check for leaks while you there too. The washer fluid tank as it tends to crack and leak fluid. |
