2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Disappointed with my quarter mile times
      08-24-2016, 09:06 PM   #1
esp260
Drives: 228i Msport 6MT
Went to the drag strip today and my best time in my 228i was a 15.4. Most of my runs were in the high 15s...
Any tips on lowering that time? My runs seem pathetic considering magazines rate them at 13.9 for a quarter mile.
      08-24-2016, 09:21 PM   #2
Luminous
Luminous's Avatar
743
Drives: 2019 M5 Competition
How are you launching? What tires? What tire pressure? How much fuel in the tank? What were ambient temps and humidity? Many factors will affect your times.
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      08-24-2016, 09:30 PM   #3
esp260
I was launching it at 3k since that is what the revs are held at in first gear. Using stock summer run flats at recommended PSI. Had less than a quarter tank of fuel. Not quite sure about temps and humidity.
Do people typically raise or lower their tire pressures for a better time? Will launching with traction on/off make a big difference?
      08-25-2016, 06:32 AM   #4
OpenAir
OpenAir's Avatar
Drives: Enzo F23 228i
2015 BMW 228i  [0.00]
What were your 0~60 times? Are you getting any wheel spin?
      08-25-2016, 08:12 AM   #5
Rayscott
Drives: BMW 228ix
Wow, my X3 can do better than that. Keep practicing.
FSociety3812.50
      08-25-2016, 09:34 AM   #6
Tpeterson
Tpeterson's Avatar
Drives: 228i MSport/THP/MT/
The only way I can avoid bogging the engine down and get enough wheel spin is to turn the dsc completely off (hold the button for a few seconds).Even then it's hard to get the times the magazines publish - in my case 0-60.The car/engine combination just doesn't seem made for drag racing!
      08-25-2016, 09:41 AM   #7
bimmerfile
bimmerfile's Avatar
621
Drives: 2019 BMW X2 F39
Went to the drag strip today ................................
2019 X2
Appreciate 4
      08-25-2016, 12:17 PM   #8
Your 60 ft times must be horrid. What was your trap speed?
      08-25-2016, 01:20 PM   #9
Luminous
Luminous's Avatar
743
From my experience, for best results you should launch either using the factory launch control or with traction completely off. Also I would reduce tire pressure by 1 or 2 psi and add a bit of e85 or high octane race gas to keep your timing in check.
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      08-25-2016, 01:41 PM   #10
wtfbrah
Drives: None
have you tried pushing the gas pedal down harder
jk, but this is why i considered xDrive. launches are fast as fuark. absolute grip at lower speeds is phenomenal. but then, RWD w/ LSD has gotta be way more fun
      08-25-2016, 02:26 PM   #11
OpenAir
OpenAir's Avatar
Something must be wrong, I have a cab which is much heavier and with FBO and Enzo tune it pulled a 0-60 ~ 5.4, and a 1/4 Mile ~ 13.9 @ 100mph.
With just an Enzo tune and AA Exhaust she pulled a 0-60 ~ 5.5, and a 1/4 Mile ~ 14.2 @ 98mph
I will say that I can't match Enzo's numbers, I'm much slower...
      08-25-2016, 03:37 PM   #12
Rayscott
Drives: BMW 228ix
My drag racing days are way behind me. Used to drag a 57 BelAir and 66 GTO. Last cars to drag were my S2000's. I'm content with the performance of the 228ix. It's well balanced, handles well and is quick. The modern cars of today would leave most of the old muscle cars in the dust.
      08-25-2016, 03:56 PM   #13
Kolyan2k
Drives: 2006 S2000
LSD should definitely help. Without traction you are just spinning wheels and with traction enabled it just cuts power
      08-25-2016, 07:46 PM   #14
esp260
I was only able to spin my wheels on 1 run. My 0-60 time was about a 2.4.
      08-25-2016, 07:47 PM   #15
esp260
I think my best trap speed was 93 mph. 60 feet times were about 2.4.
      08-25-2016, 07:48 PM   #16
esp260
I'm wondering that too, could I have gotten a lemon 228? Or is my shifting/launching THAT bad...?
      08-25-2016, 07:55 PM   #17
B_Rice
B_Rice's Avatar
Drives: 6spd Estoril Blue M235i
Probably the latter.
Estoril Blue 6spd M235i LSD Sunroof delete AWE touring exhaust Fabspeed sport cat
      08-25-2016, 08:42 PM   #18
nike001
Drives: 2018 718 Cayman
Yep.
Do what the car was actually meant to do and take it to a track with turns and stuff. These cars aren't meant to hang at the drag strip.
      08-25-2016, 09:26 PM   #19
esp260
Originally Posted by nike001 View Post
Yep.
Yeah I guess I'll stick to the track. Had my first HPDE event 3 weeks ago and was extremely impressed with the 228!
      08-25-2016, 09:28 PM   #20
esp260
Any tips on 1-2 shift? Seems like even if my shift are THAT bad i should be at least breaking 15.
Oh well...I guess I'll keep practicing my launches and shifts and see if my time improves.
      08-25-2016, 10:05 PM   #21
HeyMoe53
Drives: '17 M240 AW/Coral MT
I'm kind of puzzled why any BMW owner would worry about drag strip times. For many of us, it is not about that at all.
      08-25-2016, 10:09 PM   #22
esp260
It's just out of curiosity, the drag strip is only about 15-20 minutes away from where I live so I decided to go yesterday to see some real world times.
wjones14658.50
