01-24-2021, 09:51 AM | #1 |
Rep 62
Intermittent burning smell coming out of air vents
I have a 2015 m235 and I have been getting this burning smell coming out of the air vents.
The smell happens when the heat is on but it's random. It can be normal for the first say 5 minutes and then you get 2-3 minutes of a burning smell where I have to open the windows to get some clean air. Its not consistent as it might happens 2 or 3 times in a 20 minute ride. Usually lasts a couple of minutes each time. Heater core problems maybe? Any ideas? |
01-24-2021, 03:25 PM | #5 |
Rep 970
01-24-2021, 06:23 PM | #7 |
Rep 62
I tried to have a better look today. The smell might be more like exhaust fumes coming into the cabin from the air vents than actual burning.
I can see what looks to be exhaust fumes between the firewall and the back of the engine on the battery side. It’s very light smoke and I cannot see the source. I think I have to bring it somewhere and put in on a lift. It’s just strange that it gets really bad in the cabin for a few minutes and then it stops. |
Rick.Null22.50 |
01-24-2021, 09:04 PM | #8 | |
Rep 198
01-27-2021, 04:52 PM | #9 |
Rep 62
01-27-2021, 06:01 PM | #10 | |
Rep 351
back to the price. $900 seems high... though, I haven't done a lot of research on that job. at that rate it's a 7 hr job. doubt it's that long. edit: did some reading. $900 is close to fair, hah! |
01-27-2021, 07:28 PM | #11 | |
Rep 3,497
delvec0389.50 |
10-26-2021, 07:51 PM | #12 |
Rep 485
Just had the same smell ...
Just had the same experience. The smell is faint but showed up randomly. Has a bit of burnt engine oil smell with a tiny bit of sour smell in it. (Just replaced oil about a month ago with LiquidMolly, so the sour smell may be LiquidMolly.)
Can anyone confirm that this is Valve Cover Gasket (VCG) ? I have highlighted where the oil is found with RED circle and arrow in the pictures. My M235xi is around 53K miles, I ordered VCG and 6 spark plugs. I have replaced VCG before for my previous E46; so, I think I'm good with doing it.
2015 M235i xDrive 8AT
10-26-2021, 09:24 PM | #13 | |
Rep 445
10-28-2021, 09:49 PM | #15 |
Rep 485
REF:
Not sure now after watching this video whether I should just replace the VCG or the whole Valve Cover. Looks like cylindrical round PCV in the center also has a seal that is fully integrated into the cover. For those of you who have replaced your VCG, did you have to go in there later to replace the central PCV cylindrical thingy ? I don't want to have to dig into the Valve Cover the second time to replace more seals. What are your thoughts?
10-29-2021, 10:10 PM | #16 |
Rep 485
There are more than one YouTube video to do this. None are specifically for the F22.
11-11-2021, 02:01 PM | #17 |
Rep 485
In the process of removing stuffs hanging off the Valve Cover (VC), I unhooked the PCV vent hose successfully but when I touched the hose itself, parts of it crumbled into powder.
Hmmm ... looks like the replacement of the VCG has now extended to replacing the PCV vent hose. Just ordered 2 of it (one OEM and the other REIN) just in case. Any look-ahead muddy waters which I need to be aware of when replacing PCV vent hose?
11-11-2021, 02:18 PM | #18 |
Rep 485
Any videos or articles about F22 PCV vent hose replacement you have used previously and would like to share, I'd appreciate.
11-11-2021, 05:01 PM | #20 |
Rep 485
Fuel lines connectors are different on my F22
From the BMW TIS, there are nuts on both ends of each fuel line to the Valve Cover: see attached.
But, mine only has one nut on the ignition coil side and no nut on the other end. Any ideas why and how do I remove the fuel line ?
11-11-2021, 09:40 PM | #22 | |
Rep 485
Looks like they are flexible; so, my intention is to unseat the VC and gently side it out under the partially unmounted fuel lines with the help of another person. If that does not work, I will have to remove the vertical main fuel line, which you suggested.
