2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Thoughts on OEM LSD vs $250 Progressive LSD
      04-15-2020, 04:02 PM   #1
Zyzzthetic
6 speeeeeeeeeed
Zyzzthetic's Avatar
Drives: 2017 M240i 6-Speed Manual
Found these guys when looking for parts. The company is called Racing Diffs, they make an interesting product so I decided to dig deeper.
Can somebody explain this to me? My car currently doesn't have a diff and I've been looking at buying one and saw this on ebay. Thoughts?
Ebay listing
https://www.ebay.ca/itm/264498938646
Video
17' 240i 6MT - black on red
      04-15-2020, 04:25 PM   #2
dradernh
dradernh's Avatar
4413
Drives: 2017 M240i
Originally Posted by Zyzzthetic View Post
Thoughts?
What's it going to cost you to have it installed, or can you DIY?
Do you know what its strengths and weaknesses are compared to the other diffs available for our cars?
I'm no expert on diffs, so I have no idea. My habit is to just go to Dan at Diffsonline, tell him which car I have now and how I'm using it, ask him which diff I want and how long it will take - and then send him the money. Same process as buying the BMW diff except there's more choice.
WolfGTI716.00
      04-15-2020, 04:33 PM   #3
Zyzzthetic
6 speeeeeeeeeed
Zyzzthetic's Avatar
Thoughts?
To be honest I don't know much about LSDs.
What I do know is that I'm sicking of seeing my traction light go off while turning at 15 KM/Hr
How are the ones from Dan compared price wise?
      04-15-2020, 05:07 PM   #4
aerobod
aerobod's Avatar
3626
Ebay listing
Video
I would steer well clear of this limited slip diff addition for the following reasons:
- several of the photos show poor or damaged surface finishes, indicating poor quality parts.
- the face of the side gears is used as the metal part of the "clutch pack". They say to grind these to exactly 30mm spacing, to do this accurately through a good machine shop will likely take several hours of setup, costing more than the kit itself.
- the surface area of the friction washers is so small, that there will be very little locking effect anyway.
Maynard3848.00
      04-15-2020, 05:20 PM   #5
dradernh
dradernh's Avatar
4413
Drives: 2017 M240i
1) That's a good reason to pass on products like this one.
2) You can see what Dan offers at: https://diffsonline.com/. As you can see in my signature, I went with the Wavetrac - it has no clutch packs that will someday wear out. Plus, Dan recommended it, and I've relied upon him for years.
Whichever diff you end up with, the installed cost is generally going to be in the USD $2500-$3000 range. No idea how different it is where you are.
      04-15-2020, 05:23 PM   #6
Zyzzthetic
6 speeeeeeeeeed
Zyzzthetic's Avatar
2) You can see what Dan offers at: https://diffsonline.com/. Whichever diff you end up with, the installed cost is generally going to be in the USD $2500-$3000 range. That's just how it is.
Dammit BMW really did this to us ):
      04-15-2020, 05:34 PM   #7
dradernh
dradernh's Avatar
4413
Drives: 2017 M240i
For significantly less money, an LSD could have been a factory option.
BMW didn't bother because the take rate would have been tiny, just like it is with manual transmissions. MT fans are noisier than are LSD fans, however, so we got our MTs, but we had to pay a couple of thousand extra for the LSDs.
This is just part of what you sign-up for with BMW.
aerobod3625.50
WolfGTI716.00
      04-15-2020, 07:29 PM   #8
Maynard
Drives: 228iX & M2C
OMG, this is hilarious. It can't be for real, can it. Do several thousand dollars of machine work to a diff, and then cram a lump of potmetal into the gears. And lines like [comparing to how it isn't like that thing that wrecks civic trannys] "its a RWD anyway, so the worst that could happen is you need to replace an inexpensive differential". I really wanted to see them try to put some horsepower thru this, but couldn't find that.
OP, just pay the dealership, or a good indie place if you go aftermarket.
WolfGTI716.00
dradernh4413.00
      04-23-2020, 05:55 AM   #9
costa84
Drives: E92 M3, F87 M2 OG
I had some experience with exact same kit on E46 330. LSD was not working properly. I dont recommend it. It is just waste of money.
Rocky58122.50
      04-30-2020, 06:43 PM   #10
Rocky58
Drives: m240xi
When I saw the parts of that thing, it reminded me of my wife's Kitchen Aid attachments: Name:  Untitled.png
Except those look better machined
ggggbmw432.50
      05-01-2020, 10:42 AM   #11
This is not what you want unless drifting only. This will cause a full lock experience (all the time), this is for cheap folks who will spend more in the long run anyway...
      05-02-2020, 03:37 AM   #12
Zyzzthetic
6 speeeeeeeeeed
Zyzzthetic's Avatar
Thanks for all the responses. I wasn't planning on getting this anyways, I just wondered if this thing could possibly be legit @ me
      05-08-2020, 01:56 AM   #13
thormessiah
thormessiah's Avatar
165
Drives: 2008 BMW 335i Coupe
2008 BMW 335i  [0.00]
Don't want to jack the thread, but hows that 17 in the front and 18 rear conversion working for you? Did you have to change anything major? Any changes in driveability and comfort?
      05-08-2020, 10:09 AM   #14
dradernh
dradernh's Avatar
4413
Drives: 2017 M240i
It's a track setup, and it works fine there. Also changed for the track and so the 255 R888R tires would fit: coilovers, negative camber of -2.6° F & -2.2° R, a bit of a fender roll F & R, and 5mm spacers in the rear. Driveability: much improved; Comfort: N/A.
