2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Stock boost?
      07-26-2014, 03:20 PM   #1
Jerich0
Love to Drive
197
Drives: X4 & M4
Stock boost?
Hello guys, just wanted to know the stock boost number in psi for our cars?
Thanks
JC
      07-26-2014, 03:59 PM   #2
Delnari
Delnari's Avatar
Drives: 2014 MG F22 Auto
Should be around 7 lbs for the M235i, not sure what the N20 engine is pushing.
      07-26-2014, 04:17 PM   #3
Jerich0
Love to Drive
197
Drives: X4 & M4
Yes I am looking for the n55... 7psi? Seems a bit low dont you think?
      07-26-2014, 04:40 PM   #4
HX_Guy
Drives: 2014 BMW M235i
I'll check later today and report back.
2014 BMW M235i 6MT
2012 Mercedes E350 Bluetec
      07-26-2014, 06:14 PM   #5
Delnari
Delnari's Avatar
Yes, the six cylinder twin scrolls are low PSI. I know it sounds low given my WRX was 12.5 PSI stock and boosted to 21 lbs at Stage 2+.
      07-26-2014, 06:30 PM   #6
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
its 10-11 PSI you will make higher boost in 4th and 5th for example to to the engine load ... and lower boost levels in 2nd and 3rd
      07-26-2014, 06:58 PM   #7
daisy16905
Drives: 2014 M235i
Is it 9 psi with 2 psi overboost with M235i?????? Getting us to 320 HP vs. normal 300 HP.
M235i (Black) Auto, JB 4 (Stage 2 / Map 7 with EWG & FF wires) ER DP, resonator delete, running E35, BMW Performance LSD, Hankook Ventus R-S3's (255/35/18 & 235/40/18) ATE Super Blue Racing brake fluid, 35% tint, black grills!
      07-26-2014, 07:11 PM   #8
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
Looking at the logged data with visible ecu psi against DME values i have the M235i making 11psi
      07-26-2014, 07:47 PM   #9
HX_Guy
I tested gears #2, #3, #4 and #5 and all of them got up to 11.3 PSI. Gear #1 only did 9.X.
Also tested Comfort, Sport and Sport+ and all reached the same boost levels.
2014 BMW M235i 6MT
      07-26-2014, 07:51 PM   #10
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
guess I was close then
      07-26-2014, 11:44 PM   #11
daisy16905
Drives: 2014 M235i
HX guy - What were you using to get all that vehicle detail?
      07-27-2014, 01:14 AM   #12
HX_Guy
OBD Fusion app and ELM327 OBDII reader, see here: http://www.2addicts.com/forums/showthread.php?t=1013843
2014 BMW M235i 6MT
      07-27-2014, 01:40 AM   #13
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
I see you use the JB4 stage 2 hardware for tuning ? Why dont you use the JB4 app for android,iOS,mac or win ? Sorry im confused ? Logging with the JB4 you can log DME and actual PSI and target boost settings ... pretty straight forward.
      09-09-2014, 01:18 PM   #14
Guynamedsean
Drives: 2012 Carbon Black 650i M Sport
My cla 45 has 26 psi. Fucking insane.
Engine or grenade?
      09-09-2014, 02:40 PM   #15
JustinCredibleM
Drives: '15 GT-R, '02 996TT
Engine or grenade?
Its a good engine. Even the stock Evo X runs around 22psi.
