01-24-2017, 10:10 PM | #1 |
Rep 281
Lease return tire question, Conti Extreme vs PSS
I know I'm more then 18 months away from my lease return, but with a new job I will be driving a lot more then I have in the first half of the lease.
Car came with PSS tires, but on tirerack right now they have a really decent deal on Continental ExtremeContact DW. 300 dollars less then the PSS tires. The safe thing to do would be to mount the Conti tires now, and save the PSS, but then I'd be paying for mounting 2x. I'd rather burn out the PSS, then mount the Conti tires closer to turn in. Would these tires qualify? Or how can I go about verifying? |
01-25-2017, 12:34 AM | #3 |
Rep 671
Easy--call the dealer. I know they are fussy about turning in a car with non-RFTs if it was delivered with run-flats (found out the hard way).
This time around, I took the run-flats off my '13 128, and they are sitting in the basement waiting to go back on the car when I decide to trade it in. I did have the DW tire on my '09. Big improvement over the Pirelli run-flats. Liked them better than the Pole Position S-04s I put on my '13. |
01-25-2017, 07:01 AM | #5 |
Rep 8,942
They need to be the same type (run flat or not) that the car came with. Need to be same size, if yours came w summer rubber must return a staggered set. Finally must be same load and speed rating or better. There is no rule about brand.
01-25-2017, 09:05 AM | #7 | |
Rep 281
Both sets on tirerack are Front 225/40ZR18 Rear 245/35ZR18 Conti Extreme are 92YXL front and rear, UTQG: 340 AA A PSS are 88Y front, and 92Y XL rear, UTQG: 300 AA A Both are rated as max performance summer tires. FYI, The Conti are selling for $478.2 vs $760.2 for the PSS. + shipping. |
01-25-2017, 09:14 AM | #8 | ||
Rep 8,942
Basically bottom line you need to turn the car in as you got it or better. Not talking better from a handling perspective, PSS are great. Just from a tire spec perspective.
01-25-2017, 10:56 AM | #9 | |
Rep 957
01-25-2017, 11:59 AM | #11 | ||
Rep 8,942
01-25-2017, 04:12 PM | #12 |
Rep 671
IIRC, I once read an article that the treadwear rating translated into thousands of miles of wear under average use, tested on whatever method is used.
So, 340 treadwear would translate into 34,000 "average" miles. Of course, most people on this forum don't drive their cars in an "average" way. And, rear-drive Bimmers are harder on rear tires. And maybe my old, feeble mind doesn't remember the story quite right. At the least, you could use the treadwear rating as a comparison point. Higher means more expected treadwear. I did put the DW tires on my '09 1-series, and I liked them. Wish I had done the same on my '13. |
01-25-2017, 05:14 PM | #13 | |
Rep 281
They test tires by putting them on a truck setup, with a few standard test tires. Then rating is then based on how much less the tires wear out compared to the test tire. |
01-26-2017, 10:41 AM | #14 |
Rep 2,882
Seems like best bet is to ask at the dealership you plan to turn it in to, since that will be the deciding point. Even if they 'should' be OK with another brand, you probably won't want to hassle with them over it, and you still have the option of setting the old tires aside to remount (not that big a cost to do an extra remount).
01-26-2017, 11:54 AM | #15 |
Rep 8,942
Also I don't think anyone mentioned if you're going to lease another car w them there is a little wiggle room. If you're just under they can let it slide - don't go in w completely bald rubber though.
01-26-2017, 10:34 PM | #17 |
Rep 671
And yes, there is a pretty decent explanation on Tire Rack's website, along with traction grades, and speed rating. Not bad to read when one is tired of reading about how the Steelers screwed up (they did).
01-28-2017, 06:19 PM | #18 |
Rep 63
Can you guys confirm that at lease turn-in, you don't need OEM and they won't require tires with the star marking? I must likely will need to change tires ahead of time but I wouldn't mind saving a few bucks by not putting a set of PSS...
