12-21-2020, 12:56 PM | #2135 | |
General
10449
Rep 40,805
Drives: 2018 Alpina B6 650ix GC
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
02-04-2021, 08:04 AM | #2136 | |
Rep 3
I don't have a battery charger so how can i make sure I avoid the DME ECU as I will need to do all my coding when the car is running? Thanks |
02-04-2021, 08:15 AM | #2137 |
General
10449
Rep 40,805
You can code whole car with motor running, except DME.
02-04-2021, 08:02 PM | #2138 |
Rep 5,262
02-12-2021, 09:16 AM | #2139 |
Rep 142
Drives: 2021 BMW M440i XD
Garage List 1984 Mazda RX7 GSL [0.00]
1999 Subaru Sambar [0.00] 1970 VW Beetle [0.00] 2024 BMW Z4 [5.00] 2021 BMW M440i Coupe [0.00] |
I have got a 2020 F23 with LED headlight (non-adaptive), just wondering if I can code the VLD with it.
Also any chance I can lower the speed to activate LDW? Thanks. Last edited by cowymo; 02-12-2021 at 09:32 AM.. |
02-12-2021, 10:39 AM | #2140 |
Rep 167
I'm pretty sure the lights have to move for VLD. It's more than just leveling. Was it decoded from your car? Look up your VIN to check.
02-12-2021, 01:55 PM | #2141 |
Rep 142
02-12-2021, 05:48 PM | #2142 |
Rep 167
F22 coding cheat sheet
What I meant, was go here and look up your VIN: https://www.mdecoder.com
And look for S5AP and S8S4. Those are the two decode codes for these features. |
02-13-2021, 09:06 AM | #2143 | |
Rep 142
02-14-2021, 08:01 AM | #2144 |
Rep 29
Drives: 328i 07
pikcachu I am a newbie to coding, is it possible for you to share what i can do with this software? it seems there is alot of coding can be done through this, but i also don't want to mess around with things i don't know .
So, can you please share a list of common things i would benefit from using this software.
MHD Stage 2+, xHP Flashtool Stage 3, VRSF Catless Downpipe, VSRF Intercooler Upgrade, Arma CF Air Intake, M Performance Exhaust.
03-01-2021, 03:45 PM | #2145 |
Rep 13
Coding cruise control
I have an 2019 M240 fitted cruise button and attempted to code using genuine ISTA software which I have access to through my garage. Coding failed, when I press cruise button It comes up saying cruise ready but when I try to set speed it faults.
Is it worth trying coding with Esys, if so where where do I start 👀😂. Thanks |
03-10-2021, 06:40 PM | #2146 |
Rep 95
Idrive is stuck in a reboot loop. I have ista+ over ethernet and can connect successfully. I can pull faults from HU but the reboot loop ~30s is causing issues. Im brand new to ista and but have tech background. Looking for a little guidance. Am i able to update software and code in ista over ethernet or do I need an ICOAm cable? Really appreciate any help.
03-27-2021, 07:48 AM | #2147 |
Rep 92
The LED interior roof lights are annoying me. In the evenings /at night they dim down but have some serious PWM flicker. A while ago a saw a code somewhere but cannot find it again. There are two variables for normal and dim brightness and it should even be possible with carly to code.
Does someone remember how those two entries are called and where to find? |
04-01-2021, 03:09 PM | #2148 | |
Rep 92
Helligkeit Innenbeleuchtung – Aufsperren => sehr hell (FEM) Welcome Lights – interior lightning => sehr hell (FEM) This should prevent the interior lights to be PWM dimmed if one opens the door at night. However I could not figure out the FEM variables for "Aufsperren" with regular coding. Any ideas? |
05-05-2021, 06:02 AM | #2149 |
Rep 1
Hey Folks,
New owner here, I've had a good google and a look on YouTube but I can't seem to find a straight answer for my coding question; I'm looking to enable Speed Limit information in my cluster as it's the only feature I seem to be missing. I've got a KAFAS camera in my 2020 M240i but I'm new to all this so I'm not sure what's actually involved in enabling the feature. There's a bunch of guides about installing a module if you don't have a KAFAS, but as I have one I have absolutely no idea what to do Any help for a noob would be massively appreciated |
05-06-2021, 06:29 PM | #2150 |
Rep 345
05-07-2021, 04:46 PM | #2152 | |
Rep 85
So quite often I'm doing 45 as there's no kids around, but my display says 25. |
07-19-2021, 04:13 PM | #2155 |
Rep 536
07-20-2021, 01:12 AM | #2156 |
Rep 6
