2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Adaptive LEDs retrofit on pre-LCI F22
      01-07-2024, 06:52 AM   #1
boldorider4
Drives: BMW 220i F22
Hi all,
does anybody know if it is possible to retrofit Adaptive LED headlights like those found on LCI F22s on a pre-LCI F22 with HID headlights?
I know some people replace the HID bulbs with LED ones thus getting much brighter lighting, but I was wondering if the whole headlight ensemble of the LCI can be retrofitted. They also sport a slightly slicker design and the turn signal also looks different being an LED as opposed to a halogen bulb.
      01-07-2024, 12:43 PM   #2
llebnave
llebnave's Avatar
Drives: 2017 M240i, 2007 335xi
I can’t find anyone that has gone from pre-LCI halogen to LCI adaptive LED. It is likely possible, but even going from pre-LCI adaptive xenon to LCI adaptive LED (which has more discussion at least), it can be be prohibitively expensive. You would need not just the headlight housings but different wiring harnesses and the supporting modules and heatsinks as well. See here: https://www.bimmerpost.com/forums/sh...php?p=22685948 and https://f87.bimmerpost.com/forums/sh...54&postcount=7 for example.
      01-24-2024, 02:37 PM   #3
sec_mk3
Drives: bmw f22 bmw g20
I have a 2017 OEM pre LCI halogen to OEM LCI adaptive.
I did purchase a harness and remote coding I do not have all of the adaptive functionality.
It can be done
      01-30-2024, 01:11 PM   #4
Dom147
how much did it end up costing you?
      02-01-2024, 11:42 PM   #5
Kernel Kurtz
Kernel Kurtz's Avatar
345
Drives: 2020 M240i xDrive
Originally Posted by boldorider4 View Post
Hi all,
HID (High Intensity Discharge) lamps - aka xenons - are not the same as halogens, so the question is unclear.
