2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Amplifier no coding data stored / ASD no valid coding for equalization
      05-27-2021, 10:20 AM   #1
Drebeemer007
Drives: 2015 M235i
Hey guys,
I have a sound system issue with my BMW. When radio is on, music will play for a few seconds and cut off then play again for few seconds and cut off (this cycle repeats). If I turn the volume off a crackle and pop noise comes from every speaker one at a time. Active sound does not work either.
I scanned my car and I have the following codes:
- B7F481 (AMPH: No current coding data stored)
- B7F484 (AMPH: Control module is not encoded for the vehicle)
- B7F4A8 (Bass speaker, front left: Malfunction)
- 8053A5 (ASD: Invalid coding data for equalizing)
From my research the amplifier needs to be coded to the car. Are there any DIYs out there that can show me how to fix this on my own.
Any suggestions will help.
Thank you,
Andriy
      08-04-2022, 01:34 AM   #2
Harmouch
Harmouch
Drives: Bmw 435i
Same b7f484 code...how you solve it?
      08-14-2022, 09:38 AM   #3
kubax86
kubax86's Avatar
No_Country
1790
Drives: M2
Simply code by E-Sys
      08-17-2022, 05:01 PM   #4
juantg93
juantg93's Avatar
Spain
Drives: BMW F22
You need code with esys. If you need help can contact with me by telegram. Mi username is juantg93
      03-12-2024, 02:47 PM   #5
Pedropp
United Kingdom
Drives: f33
Hi.
I have this same problem.
I don't know how coding.
Tags
amplifier, fault, hifi, hifi audio issue, sound system, sound system fault
