BMW 3-Series (E90 E92) Forum
Electrical errors related to k-can
04-29-2024, 05:32 PM | #1 |
Rep 11
Hello I have a 2007 bmw 328i and it runs fine but suddenly I have a ton of errors all related to k-can. Since it maybe a short/water corrosion where should I start looking? really appreciate any advice.
0093EB MRS: TCU output - short circuit to positive 00C944 K-CAN line fault - general. / Bus line fault - general. 00C905 K can high line / CAN high, short circuit VB 00C907 Controller K-CAN, bus off / K-CAN communication fault / K can communication 00A6CF JBE: AUC sensor 00C904 K can low line / CAN low, physical error 00D904 CAS: K-CAN line fault 00A0B0 CAS: Input, brake lights, implausible 00E184 CD / M-ASK / CCC / RAD2 / CHAMP -GW: K-CAN line fault 00E18F Central registry does not match the target configuration (error registry new). 00E444 SMFA: K-CAN line fault 009CD2 FRM: Drive, mirror pivoting, driver's side, faulty 009CBD FRM: Communication with step motor controller on the left disrupted 009CBE FRM: Communication with step motor controller on the right disrupted 00E584 Unfortunately, no error text available / CAN low, physical error / Bus line fault K-CAN / K can short 002DED DME: Power management, closed-circuit current violation 00A3AD Message (engine data, 0x1D0) faulty, receiver KOMBI, transmitter DME-DDE 00A3AE Message (engine speed, 0x0AA) faulty, receiver KOMBI, transmitter DME-DDE 00A3AC Message (distance travelled, 0x1A6) faulty, receiver KOMBI, transmitter DSC 00A550 Message (speed, 0x1A0) faulty, receiver KOMBI, transmitter DSC 00A554 Instrument cluster: No message (telephone) 00E104 CAN error wire / Can low error Last edited by fespinoza831; 04-29-2024 at 05:44 PM.. Reason: Image wasn't visible |
04-30-2024, 02:17 AM | #2 |
Rep 2,782
check the rear right box in the trunk, there is a PDC module which can be damaged by water
the next thing is if windshield is replaced by not very professional people and water now goes to junction box behind glovebox if you have a sunroof, you need to check if drains are clogged, they are running in a and c pillars with outputs under the car
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
M-technik-32137.00 |
