2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning MP: Dyno day with Stage 2 M235i. JB4 and Flash Tuning results
      05-06-2016, 04:18 PM   #67
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
I believe PJinCA wants to bare witness the fitness. Yeah, MP reworked the maf and wastegate and now the stubborn F10 535 is making 340-50whp and peak about 17psi and holding 13 across the band. We'll dyno tune next week. Lookout tuned F30's...
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles
      05-20-2016, 03:36 PM   #68
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Any updates on the dyno or are the #'s on the first post still valid?
Any new #'s on FBO pump and FBO e30ish?
Also would like to see a dyno that takes the car closer to redline..
      05-20-2016, 03:41 PM   #69
ocN55
ocN55's Avatar
Drives: '15 M235i 6MT/ '16 M3
On Wednesday I made 392whp/445wtq on 91 octane. Same dyno, new flash without stacking jb4
Graphs will be posted soon.
As for E30, we didn't have time for it. Our goal is to perfect the 91 octane tune before blending. And I have to say, since working with MP, I've lost urge to run ethanol.
FBO M235i r
F80 M3
      05-20-2016, 03:52 PM   #70
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Wtf?!
JB4 stack?
Dyno graph?
Please share log if you have it
      05-20-2016, 03:53 PM   #71
ocN55
ocN55's Avatar
Wtf?!
JB4 stack?
Dyno graph?
Updated my other post!
I logged all the runs with the dyno numbers. I'll share them in a but
FBO M235i r
F80 M3
      05-20-2016, 03:58 PM   #72
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Yeah seriously, not sure if ethanol will make a difference. You might already be reaching the stock turbo limit on 91oct.
Keeps us posted.
      05-20-2016, 04:05 PM   #73
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
ocN55 STD/Smoothing 5 graph 392/445 ?
how much more boost did he increase it to ?
congrats
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      05-20-2016, 05:18 PM   #74
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Damn ocN55 91oct! Alex is killing it. ROBNYC you might have to switch tunes
IG: @bmwdoubles
      05-20-2016, 10:40 PM   #75
ocN55
ocN55's Avatar
Alrighty... here are some logs for the savvy folks
14:23 Log has LOTS of boost for those who want to see high boost
15:16 Log best dyno numbers
16:20 Log of final flash
http://www.datazap.me/u/sc67065/mp-d...log=0&data=1-4 (click the circle arrow thing to cycle through the 3 logs)
Here's one street log I did today. Splashed 2 gallons of leftover E85 I had, don't think it is significant enough though.
Cylinder 1 timing looks excellent to me for the fuel used.
http://www.datazap.me/u/sc67065/mp-f...log=0&data=1-4
MissionPerformance
FBO M235i r
F80 M3
FSociety3812.50
      05-20-2016, 10:46 PM   #76
ocN55
ocN55's Avatar
A final note I'd like to make. I know a lot of folks are looking to see high boost numbers. But after spending hours on the dyno, doing pulls, adjusting, logging... boost does not tell the whole story. I guess what I'm trying to say is that there is A LOT more to making good power than just high boost. In fact, in one dyno run when Alex and I tried to stack JB4 Map 6, I was boosting 17-18psi the whole rev range but had the worst dyno run. Timing was also quite poor. I think power was 373whp which was less than my baseline for that day. Nonetheless, I was shocked to boost that much on pure 91 octane.
FBO M235i r
F80 M3
      05-21-2016, 12:44 AM   #77
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
You're correct ocN55
Where's the dyno?
You make a good point, peak numbers is nothing whats important is area under the curve
But boost & other factors are very important. More boost doesn't mean better like you just explained
IG: @bmwF9XG80
      05-21-2016, 01:12 AM   #78
ocN55
ocN55's Avatar
Where's the dyno?
Don't have them yet, gotta wait for Alex to post some
FBO M235i r
F80 M3
      05-21-2016, 01:17 AM   #79
ocN55
ocN55's Avatar
Here's all I've got for now via a text. One of our many runs...
FBO M235i r
F80 M3
      05-23-2016, 09:16 AM   #80
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Exactly.
If you just use JB4 (like me) it's all about the boost because they can't directly adjust timing with JB4. So only way to make power with just JB4 is turning up the boost to the limit (octane, fuel, turbo).
I assume with your flash they have timing control (this is why your timing looked weird to me earlier) So you're getting close to the stock turbo limits with 91oct and less boost. This is great!
      05-23-2016, 09:33 AM   #81
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
MissionPerformance
All look good.
The log with the best dyno #'s is running less boost and better timing then your high boost log
Your final flash log show higher IAT = higher ignition. Probably why the Hp/TQ difference.
Trims look really good too since you're running 91 and low boost.
Interested to see what #'s it puts down with some e85, but you might be close to the limit already.
I'll have to check this out soon after I get a few other little things done with the car first.
      05-23-2016, 09:41 AM   #82
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
ocN55 keep me posted i want to see the the top right for Correction Factor and Smoothing as well..
bryan_f22 M235 Dinan Stage3 + Catted DP dyno'ed at 395/428 at the wheels on 93 octane .. Then removed Dinan and added a ECU Flash without adaptation it put down right away 392/448 .. These are peak numbers, but his under the curve numbers are 450 wtq as well which are way better than Dinan's under the curve and smoother curve
IG: @bmwF9XG80
      05-23-2016, 12:00 PM   #83
ocN55
ocN55's Avatar
Originally Posted by Anthony235 View Post
All look good.
Sounds good! Let me know when you're ready to join MP
And yes, my final flash tune dropped some power since it was probably the 20th+ back to back pull on the dyno lol
FBO M235i r
F80 M3
      05-23-2016, 12:01 PM   #84
ocN55
ocN55's Avatar
93 octane is worlds better than California's 91 octane. Sadly, a really unfair comparison.
FBO M235i r
F80 M3
      05-23-2016, 12:46 PM   #85
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
MP,
Can you do anything with the flash count that is stored?
      05-23-2016, 12:52 PM   #86
ocN55
ocN55's Avatar
MP,
original flash count was saved during initial bench flash. All the subsequent flashes are not triggering the flash count
FBO M235i r
F80 M3
      06-03-2016, 12:52 PM   #87
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
I will probably go with the MP flash soon. Probably keep my JB4 for logging and using map 6 w/e85 stack.
Just ordered full M Performance aero package. So once that comes in I have to decide if I want the want to do the full M Performance interior or the MP flash.
MP Flash is cheaper than doing the interior, but I already have JB4 to hold me over. I guess there are worse things to lose sleep over
      06-14-2016, 11:49 AM   #88
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Looks like you're having some serious timing issues in your latest log on n54.
I looked at the last log you posted here. Seems the timing isn't as bad then, but still not the best. When I first looked at it I didn't really look at all cyl.
Edit: different user. Sorry!
