New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      05-09-2015, 12:23 AM   #45
army_men
army_men's Avatar
46
Drives: E89 Z4 35i
2011 BMW Z4 35i  [10.00]
Thanks italy for this. Im looking to upgrade my worn out brakes to a set of F30 m sport brakes right now, i assume that's the same as M235i calipers right?
Your post really helps me out. I'm going to buy a set this weekend.
      05-09-2015, 02:47 PM   #46
nuebbes
nuebbes's Avatar
Germany
25
Drives: Z4 35i e89 + 125i e88
Take the 370mm BMW Performance Setup. This is definitely the better choice for a comparable price to the 340 mm set.
      05-13-2015, 12:25 PM   #47
pavproch
Drives: Z4 3.0i & 330ixT
Originally Posted by pavproch View Post
N2SHA sport brake package:
rotors 34106797602 (340x30mm, slotted/drilled)
caliper right 34116799466, 2pot blue + ///M badge
caliper left 34116799465, 2pot blue + ///M badge
pads 34116859066
This is what I ordered the day before yesterday, I am off next week (gone skiing, what else), but I aim to have it installed once I am back, will report then (supposedly this sould be a straight PnP)
Confirmed.
(Courtesy of Mythbusters.... )
Daily:330ix 6MT - PBX, HR SportSprings, Koni Yellows, OZ Ultraleggera 18", PI+PE, CDV off, UUC sways, M235i SportBrake (front), Cquence rotors (rear), 3.64 diffs, LSD rear
Funcar: Z4 3.0i 6MT - HR SportSprings +sways, OZ Ultraleggera 19", 5.00 diff by Drexler, CDV off, Quaife LSD, M235i SportBrake (front), Cquence rotors (rear)
      05-13-2015, 07:41 PM   #48
VailM3
Drives: 2011 Z4 35is
Confirmed.
Thanks for that and the part numbers...Looks like this is THE upgrade for the 35iS crowd here in Europe.
      05-13-2015, 09:02 PM   #49
Zteve
Zteve's Avatar
Drives: Z4 sdrive35i
Confirmed.
Looks great! Thanks for sharing!
      05-14-2015, 12:23 AM   #50
pavproch
@zteve and VailM3: it definitely is a kind of pleasure to share such a thrilling/exciting upgrade...
      05-14-2015, 02:31 AM   #51
nuebbes
nuebbes's Avatar
Germany
25
Confirmed.
Looks good!
NO this is the upgrade for <35i/S, because the rotors are smaller than the OEMs (not allowed for Europe, because downgrade).
THIS is the upgrade for the 35i/S:
BMW Performance Brakes with 370x30 mm with 4 piston calipers.
P/N's are mentioned before
      05-14-2015, 03:38 AM   #52
VailM3
Originally Posted by nuebbes View Post
Looks good!
Thanks I just realised Euro 35iS are 343 and those others are 340, thus yes need the 370. Thanks again.
      05-14-2015, 06:28 AM   #53
italy3541
italy3541's Avatar
58
Drives: Alfa Romeo 4C
Sorry I have not had time to update the chart. I have been super busy but will try to do it this weekend. Thanks everyone for all the input.
      05-14-2015, 09:16 AM   #54
CedarZ4
Drives: G05 M50i, Tesla M3P
Would the base 335i F30 caliper (the ones that come with the 340mm rotors) be PnP with a M-Sport rotor (370mm) as the calipers are interchangeable? Or would there be other parts I need to buy to make them work?
Seems like purchasing the 335i stock caliper and buying the M-performance rotor stand alone would be a better deal. That, and you get your choice of color when having it powder coated.
      05-14-2015, 04:30 PM   #55
Hujan
Hujan's Avatar
Drives: M3
I would think that you would need a different bracket at a minimum in order to space the caliper enough to clamp the bigger disc. But it would not also surprise me if the piston sizes on the brakes are different. Generally speaking a bigger disc needs a smaller piston in order to maintain the same braking force as a smaller disc.
      05-15-2015, 01:21 AM   #56
nuebbes
nuebbes's Avatar
Germany
25
No problem mate. They even have 348 mm.
Please see my post #32 - there I already mentioned the correct p/n's for the brakes.
And no, the caliper for the 340 mm disc is not p'n'p with the 370 mm disc. There is no spacer bracket available.
The best deal for you is to buy the complete 370 mm kit.
If you want to powder coat the calipers, you have to disassemble the complete calipers anyhow (incl. pistons ect). Sand blasting must be done for all calipers as well - so you have the choice of color also for the 370 mm calipers.
You can also paint the calipers with heat resistant paint - the OEM calipers are also just paint coated. So you just need color which resists min. 280°C.
By using paint coating you can also tape the pistons and you do not have to disassemble the complete calipers (although the complete disassembly would be the more quality way to go also for paint coating).
Correct regarding the calipers/ discs with the spacer.
I think the pistons should be identical because the repair/ sealant kit for the calipers are always the same as from 114d to M4 and even i8 (P/N 34116850935).
Please explain your theory regarding the smaller pistons at bigger discs more in detail.
The i8-brake could perhaps also fit to the Z4:
Rotors: 340 x 29 mm: 34116858623
4-piston-calipers (black&blue painted): 34116868231 + ...2
Brake pads: 34106866072
      05-19-2015, 05:27 AM   #57
gnx
Όλα ρόδες
gnx's Avatar
760
Drives: BMW
Great info looks like the 370/30 are the way to go here in the EU. I was wondering would it not be better to get drilled rotoars form another source as several members have done on all 4 corners?
True...Would they bolt on as is with the OEM protection plate? Has anybody actually fit 370 discs because the pnp comments refer to 340/30 rotors, correct?
      05-20-2015, 07:01 PM   #58
CedarZ4
If I'm not mistaken, both 370mm and 340mm rotors are PnP, depending on which calipers you get.
M-Performance caliper uses 370mm rotor, PnP
335i base brakes + Sport brakes uses 340mm rotors, also PnP
As nuebbes mentioned (although have not confirmed myself, based on what he is saying though), the M-Performane calipers and Sport calipers although the same, uses a different bracket, so getting Sport Calipers and buying 370mm rotors would not work.
mittu30.50
      05-20-2015, 07:03 PM   #59
CedarZ4
For those who have done this upgrade... since it is not officially approved by BMW for the e89, did anyone get coded afterwards? I know for both the E9x and F30 Performance brakes, BMW "requires" a DSC re-coding in order to retrofit them. Any down sides to not coding? Would a dealership code a E89 that is NOT approved for these brakes?
      05-20-2015, 11:36 PM   #60
pavproch
The 335i(x) rotors (are we speaking of e9x gen?) are definitely 348mm (see my signature, daily car mods)
      05-21-2015, 09:31 AM   #61
CedarZ4
Clarification: Everything I said in the previous post was in regards to the F30 (e.g. M-Performance Brakes being 370mm, as for the E9x the M-Performance brakes are 338mm in diameter)
The F30 335i rotors are 340mm, as the E9X calipers are not "big brakes" so I don't believe ever made it onto this list as as a brake upgrade.
      05-21-2015, 12:27 PM   #62
pavproch
Thanks for clarifications.
Partially off-topic: the ex-Z4 OEM calipers, carriers, pads and rotors resurrected.... quite unsurprisingly, they become a PnP front brakes upgrade to 320d e91 MY2005 ....
      06-02-2015, 01:26 PM   #63
Reverse Flash
Philippines
Drives: 2010 BMW Z4 sDrive30i
Originally Posted by ttuner View Post
Just bought these. they better fit!
http://www.ecstuning.com/Search/Site...4738/ES205607/
Got them installed already? I'm also looking to buy these, can you fit bigger rotors to this set?
      06-09-2015, 07:42 AM   #64
Theivz
Drives: Project Z
firstly thanks for such a great thread! really helpful
secondly some of these brake setups look amazing esp love pavprochs pics above - well done
Please can I get some advice?
I have a 2011 z4 e89 23i from London, UK. Should I get the f30 370mm pbmw front kit? Any news on a ebrake compatible rear kit or it the 35is rear the only option available?
thanks in advance!
this is my z4 with 19s and 12+15mm spacers:
      06-10-2015, 05:18 AM   #65
Reverse Flash
Philippines
thanks in advance!
Get this instead of you are not planning to heavily mod your car. In my opinion you only need a brake upgrade if you have the 30i, 35i or 35si or if you want it for looks or gonna do heavy performance modding.
This looks good and really affordable. My friend has it on his E36 M3, the brakes saved his life once. Lol
      06-11-2015, 06:01 AM   #66
Theivz
Drives: Project Z
great thanks. i think this is the e90 kit. others have said this is the most cost effective option. i dont think the rear is compatible but i may use the 35 is rear for that.
i want it for the occasional track day and for the looks too. i'm not planning on heavy modding but suspension and exhaust are minimum mods
its a pretty quick car in manual with the 2.5 straight 6 very impressed with the power
zpost
