2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Most Aggressive Setup on Stock Tires
      03-16-2016, 01:40 PM   #1
an4691
Drives: 2020 M2C in HS
I'm thinking about getting some aftermarket rims to use during the warmer months. What would be, in your opinion, the most aggressive wheel size for the oem pss tires. Their specs are:
Front: 225/40/R18
Rear : 245/35/R18
Looking forward to your responses!
Thanks,
An
      03-16-2016, 02:27 PM   #2
ABPReader
Deserter
ABPReader's Avatar
No_Country
215
Drives: BM&W
widest rims for front tires are 8.5"
widest rims for rear tires are 9.5''
About the ET, front ET35 and rear ET45 should work but I'm not sur that it is the most agressive setup (which doesn't need any other mods).
      03-16-2016, 04:08 PM   #3
an4691
Thanks ABPReader!
      03-18-2016, 06:54 AM   #4
Richy_Boy
Drives: M235i & e46 M3 CS
Good question/answer. I was looking at similar, so I can change the rims then replace the tyres with wider once worn.
Thanks both, Richard
'14 M235i - KONI Sport, H&R Sport, M Performance Exhaust + Aero..
Tags
tires, wheels
