2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Location of front turn signal fuses/relay?
      11-25-2015, 09:39 AM   #1
rmshashaty
rmshashaty's Avatar
Drives: m235i
Last week I had my grandmothers funeral and on the way to the cemetery while flashers were on my front two stopped working. I have leds in my front, rear and reverse lights. Thinking I maybe blew them, I bought new ones. The day I went to replace them I discovered that new leds did not solve the issue, in fact the leds never went bad and worked fine when I placed them in my rear turn signals. So I referred to the manual and discovered that they do not say where the fuses are for the front only the rear. They state to contact your dealer. I then decided to try the stock bulbs that came with the car and still nothing. I tired using the jb4 code scanner to see if anything popped up and found nothing. Before I make a appointment with the dealer does anyone have an ideas? I have a 2014 m235i U.S model.
2014 EBM/CRD M235i JB4, EWG board, FF Wires, EWG Wires, BMS Intake, ER DP, ER CP, E50, Map 7.
      11-25-2015, 10:08 AM   #2
Spydeputy
Spydeputy's Avatar
Germany
205
Warranty work, put the incandecents back in and see what happens.
      11-26-2015, 09:18 AM   #3
scrape1
Drives: '14 228i M Sport, '04 X3 3.0i
If it's like the F30, there is a panel in the glove box, and a panel in the trunk. There should be a printed card in there somewhere for reference.
