2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Thermostat CEL and incorrect temp readings
      07-01-2021, 05:02 AM   #1
icekxd
Drives: BMW M235i
Hi,
I recently had a CEL pop up. Scanned the car and two errors came up:
  • 1D2008 Map controlled thermostat stuck open
  • 10AA30 Coolant temperature sensor: group error
The only symptoms are CEL, no oil temperature reading on the digital gauge and when accessing temperatures inside hidden menu coolant is at -128 degrees Celsius and oil temp at +207 degrees Celsius. Obviously both values are impossible. Doing a live parameter check with Carly the oil temp is normal and I'm unable to check coolant temperatures (no reading). Also, the front fan is running excessively fast.
Once reset, all symptoms disappear. I do have warm air from hvac and A/C works as it should. The ambient temp outside daily is 30-35 degrees in shade. I imagine it is twice that in the sun. The engine does not take longer to warm up that it usually would. The CEL comes back irregularly, but when it does the second error (10AA30) does not reappear.
Perhaps somebody has some information if this is the thermostat asking to be replaced or whether a sensor has gone bad. I have thought that there might be some wiring issues as well, but resetting the errors would make them reappear immediately if it were the case.
Car is a 2015 N55.
Thanks
      08-28-2023, 10:52 AM   #2
coltoncox72
Drives: BMW 335i
Same Issue
Hey, I am having the same problem with my 335i, would you mind sharing what you did to fix this?
