2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning GSR Technik 228i N20 ECU Flash Tune Now Available 50whp/90wtq
      11-02-2015, 02:58 PM   #155
GSR Technik
GSR Technik's Avatar
Drives: F13 M6 | E92 M3 | '15 Mustang
Originally Posted by mge92 View Post
GSR Autosport Have you run into shaking engines upon startup after cold start with the n20's?
I haven't heard any complaints of this, it never happened to our shop car but it isn't out of the realm of normal behavior for cold start on a DFI engine. If these are stock cars I wouldn't worry too much, if it is tuned I would say perhaps the tuner is playing with stuff at idle that is better left alone.
Matt
      11-02-2015, 11:34 PM   #156
huma
huma's Avatar
93
Drives: U11 one day
My vehicle is stock and it shakes a little from a cold start. I've read of other people noticing this too, which leads me to conclude that it's normal.
      11-03-2015, 08:18 AM   #157
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
GSR Autosport have you been able to notice the RPM Idle (Stock) vs After Flash ?
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      11-04-2015, 02:32 PM   #158
GSR Technik
Idle RPM is the same before and after a tune unless someone requests a higher idle RPM. This can be done and should be done in a couple of cases:
1. There is an aftermarket sound system or other auxillary powered device that draws a lot of power from the car (higher idle will prevent lights flickering and stalling)
2. In a manual transmission car that has a lightweight flywheel that may tend to stall or become extremely noisy at stock idle RPM.
An idle bump will help greatly in both situations, but is really of no consequence to the vast majority of F-series cars on the road.
Matt
      11-04-2015, 04:47 PM   #159
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Matt
Seen some flashed cars from various tuners (not sure from GSR) that the idle is a bit different than stock.
For ex, stock the car jumps to 1100-1300 rpm or so then after 30 secs starts slowly down to 770rpm.. On the flash cars I've seen it jumps to 1000 but immediately goes idle to 850-890rpm and stays there. Regardless of temp.
It also seems in colder temps (North Eastern) the cars are having sometimes a longer crank, not sure if this has happened to any warm/hot climate flash tuned cars.
What are your thoughts ?
What are the idle rpms you are seeing in other Pre & Post N20's ?
Thanks
IG: @bmwF9XG80
      11-16-2015, 09:37 AM   #160
sonicsonic
Russia
31
Drives: 2014 335i xDrive 6MT 370whp
My tuner made cold start off for my car, but when it is cold outside I had some rpm waves. Then the tuner adjusted a little higher rpm during cold start and my car is starting up good in the morning. So the problem can be solved by any tuner who offer cold-start-off option
      11-16-2015, 12:55 PM   #161
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Could you post the before and after rpm that is idling at ?
But yes cold-start delete looks like it avoids the loud(higher idle at initial) but don't think thats good for cold temps.
Initial Cold-Start should be same as stock (Loud) 1200rpm and slowly settle down to whatever (700-900)
IG: @bmwF9XG80
      11-16-2015, 02:05 PM   #162
sonicsonic
Russia
31
First version:
http://youtu.be/rX5czW6_2xk
And the second:
http://youtu.be/3dVhXMnzgt4
I think it is hard to notice a little bit higher rpm. We began adding it from a little. If the weather will be colder and I'll have problems with cold start I know that I need only to add some more idle rpm.
      11-18-2015, 10:24 PM   #163
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
First version:
And the second:
You had to add gas on the first video? It looks like it almost stalled?
That looks around 700 rpm idle ?
before flash with DP it would stay at 1100-1200 for 30 seconds then drop to 750 slowly, after flash it goes up to 1000 then goes immediately to 880-900 idle
Record yours mge92 Stubok OpenAir shivaswrath jcruz3 2msport K320
IG: @bmwF9XG80
      11-19-2015, 03:45 PM   #164
MG 228i
Drives: Z4 m40i, 340i 6MT, i3S
No issues with mine, same as stock
      11-19-2015, 07:47 PM   #165
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
It was the Dinan Intake, but still have CEL.
Taking to dealer one last time then back to Enzo...maybe one tune doesn't fit all?!
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      11-20-2015, 11:40 AM   #166
OpenAir
OpenAir's Avatar
Drives: Enzo F23 228i
2015 BMW 228i  [0.00]
Sorry, still haven't figured out how to upload/post you tube clips directly. Anyway, she starts out at 1200 and drops right to 800 or so...exhaust tone is always consistent now.
https://www.youtube.com/watch?v=4vSw...ature=youtu.be
