08-01-2014, 06:01 AM | #23 |
Rep 1,053
You never turned the car off so it did what it was supposed to do which was kick back on when it needed more power.
I did the same thing once on the first day I had the car to find it running on the street and doubt I will ever do it again. |
08-01-2014, 09:45 AM | #24 | |
Slightly Less Obsessed
26
Rep 317
08-01-2014, 10:35 AM | #25 |
Rep 682
Drives: 2023 G80x M3C
Thanks for the responses guys, and sorry for the late reply -- I was on vacation.
- The car fan was definitely running at the lowest setting, and I am pretty sure the A/C was on, too. - I parked the car (on reverse) and immediately pressed the "P" button. This is when the car auto shut-off. I cannot recall whether I unbuckled the seat belt before or after. I am usually pretty picky about how I park my car, so I may have parked it, unbuckled by seat belt, then realized that I needed to park it better, then adjusted the parking position, at which point, the car may have auto shut-off again, and I did not have the seat belt on. But like I said, I am only trying to rationalize here based on responses, I am not quite sure exactly what happened as I was on the phone and doing all the parking stuff instinctively without thinking much. - I definitely forgot to fully turn off the car by pressing ignition button. - I also definitely did NOT turn off the fan or A/C. - I walked out, locked the car via the comfort ridge on the door handle. - At this point, the car was definitely NOT running. - Then after 5 hours, I was told that my car was on. When I got to the car, the car was locked, but running, and the A/C was running with the fan at the lowest setting. I will try to recreate this by trying out a couple of permutations people have suggested here and report back. Thanks!!! |
08-01-2014, 08:58 PM | #26 | |
Rep 1,053
If the engine switches off automatically, it won't start again as long one of these events is currently happening: - The seatbelt unbuckled and door open (at the same time as this is one condition) - The hood unlocked. So, if the OP stepped out of the car, once he closed the door, that condition was no longer being met, therefore the car should start back up again when it needs more power as he never turned the car off to begin with. |
08-02-2014, 04:21 AM | #27 |
Rep 119
Drives: 2014 M235i EBII May '14 ED
There's understanding and then there's "understanding".
Go find out and report back to us. Thank you in advance! |
