11-07-2023, 04:54 PM | #1 |
Rep 3
Low coolant sensor 2016 M235i replacement
I keep getting a semi random notice that my coolant levels are low, but I've checked and they're fine (even added some more to be certain - more then half the reservoir is filled) so I'm guessing the sensor is bad but I'll be dammed if I can find anything about a replacement sensor. What am I missing here?
11-08-2023, 10:41 AM | #3 |
Rep 1,798
There has been a couple threads on the F30 side stating that it is built inside the expansion tank. So you potentially need to replace the tank.
I'm not 100% sure if the above is true. But try to broaden your search to the 3 series side of the forum if you can't find answers here. |
11-08-2023, 11:46 AM | #4 |
Rep 5,372
The sensor is embedded into the plastic of the reservoir and there is a connector that plugs into reservoir housing. Look at the photos in the link and you'll see what I'm talking about.
https://www.ecstuning.com/b-bavarian...IaAh_hEALw_wcB
11-08-2023, 03:43 PM | #5 | |
Rep 3
11-09-2023, 01:59 PM | #7 |
Rep 3
I don't get why wouldn't they just include that as a part of the description for the tank. Something like "Plastic coolant expansion tank with coolant level sensor built in" or something along those lines. It would save a lot of confusion
11-09-2023, 03:48 PM | #8 | |
Rep 5,372
You don't need to worry about purging the system.
