06-23-2018, 01:30 PM | #23 | |
Rep 5,364
Impressive that you could leave the exhaust in place for the install but that sounds like a royal pain since you can't let the passenger side axle drop down and would be forced to pull/drop the diff sideways. I would definitely check the torque on the driveshaft axle. BMW is pretty particular about that torquing process.
06-23-2018, 02:07 PM | #24 | |
Rep 9,709
Then, yes, you set the jack sideways across the car, undo the diff mount bolts and drop the diff a little in order to pop the other side. Tie up the side shaft and pull the pumpkin out. Exactly the same in reverse, although a little harder to balance the diff, insert the driveshaft and push it back in place.....I did it on my own, another pair of hands would have been a great help. |
06-23-2018, 03:25 PM | #25 |
3612
Rep 3,578
I agree this is an excellent method for removing a diff in a rear wheel drive car where you have 8 to 10 cm of lateral space to manoeuvre the diff into, I've done this on two cars myself, it is way easier than the typical manufacturer specified method that normally requires the driveshafts to be removed from the hubs.
06-23-2018, 05:30 PM | #26 | |
Rep 9,709
SteveInfante604.00 |
