03-10-2023, 02:37 PM | #1 |
Rep 232
xDrive Alignment - Rubbing on front left fender liner
Hi,
I am not sure why I am rubbing on the front left fender liner only Mods: Millway Camber Plates Koni Sport Shocks + Dinan Springs + F80 Rear Bumpstop, E39 Front Bumpstop Ohlins R&T (I switch suspension setups when it's spring, summer, track season) Apex Arc-8 18x8.5 ET38 Hankook Ventus RS-4 245/40/18 Alignment: I would also like to see your caster specs to see if mine are out of whack TIA |
03-10-2023, 02:59 PM | #3 |
Rep 232
03-10-2023, 03:27 PM | #4 |
3727
Rep 3,632
Have you measured the wheelbase on each side (centre of front wheel to centre of back wheel with front wheels pointing straight ahead)? It should be within a couple of mm when comparing each side, if not, something is misaligned or bent.
LanceM26115.50 |
03-10-2023, 03:30 PM | #5 |
Rep 232
I will actually do that this weekend when I get time
03-12-2023, 06:07 AM | #6 |
Rep 232
