05-13-2018, 07:46 AM | #24 | ||
Rep 314
JamesTabletop11.50 |
05-15-2018, 05:13 PM | #25 | |
Rep 474
My ECU unit has been replaced, with everything being fine for 6 wks, but now this weekend I am throwing CELs again, and am wondering if the wiring harness is defective as well
Looking for 335/n54
05-16-2018, 02:59 PM | #26 | ||
Rep 314
nikman011174.50 |
05-17-2018, 02:45 PM | #27 |
Rep 45
Dinan and CELS
I have a 2017 M240i with the Dinan Stage 1 ~7k miles. Last year at 3k miles I got a CEL which the dealer (who installed the Dinan) decided to replace an intake pressure sensor and reset the ECUs (which wiped out my coding grrrrr). Last week I get another CEL, dealer claims it's due to the tune. The dealer seems stumped. Are others getting CELS from the tune? While I have lots of mods, the only other engine mod is the MPE.
05-17-2018, 02:47 PM | #28 |
Rep 45
mblaucoupe135
mblaucoupe135 - no the tune does not remove the limiter. It just gets you to the limiter a lot faster!
05-17-2018, 03:26 PM | #29 | |
Rep 296
If not, then it is not the tune! Seems like a simple test your dealer should have conducted. You can test it yourself by just loading up the app and selecting bypass. |
05-17-2018, 03:33 PM | #30 | ||
Rep 474
EDIT - ADDED: I should know more tomorrow
Looking for 335/n54
05-17-2018, 04:04 PM | #31 | |
Rep 296
I've had my Dinan Stage 1 since February and not CEL's yet. It will be interesting to see how your situation turns out. |
05-17-2018, 04:26 PM | #32 |
Rep 474
My guess is that you are good to go, and that my wiring harness is shot.
Looking for 335/n54
05-17-2018, 06:55 PM | #33 |
Rep 558
Don't remember for sure, but I think it ~15% off.
05-17-2018, 07:07 PM | #34 |
Rep 558
I also had some issues recently.
Misses, hesitation and a drive-train malfunction message on the i-Drive. But oddly, no CEL. I ran a scan with my Carly and there were numerous engine fault codes. Brought it to my dealer (also the Dinan dealer). They kept it for a day or 2 and gave me loaner. Said they reconnected everything, drove it and now there were no more codes. Gave it back to me and told me to bring it back if I had any more issues. It felt ok, I guess, on the way home. Next day I scanned it and the fault codes were back. Brought it back to them, they kept it for another couple of days and this time they said Dinan told them to apply dielectric grease to all the connections and try it again. They said they did and there were no more codes. Gave it back to me again. I've been driving it for a week or so and no codes yet. Fingers crossed... These issues haven't cost me anything and the dealer's been good about it, but it's a hassle I'd rather not have. I never had any issues with the APR flash tunes I always had on my VW GTIs.
05-18-2018, 09:45 AM | #35 | |
Rep 474
As always, Dinan_Engineering and the dealer handle it fine, taking care of everything. Gonna pick up my car this afternoon, sans defective tuner, and then bring the car back in when the new Unit arrives.
Looking for 335/n54
tennisfreak202.00 |
05-18-2018, 07:03 PM | #36 |
Rep 45
Dinan CEL
That is correct - bypass will not work, you must remove the entire harness. Going to bypass was the first thing I did, the CEL remained. It appears to be a harness issue also. The dealer knows how to troubleshoot of course, the reason why they were stumped is because there is nothing obviously wrong. Dinan and the dealer are cooperating and they are replacing at least the harnesss. I have now heard multiple stories about harness issues, hopefully Dinan has corrected the issue. As an aside, my loaner is a new X54.0e. Fun to drive a different BMW and at first (it's been a week) I enjoyed the newness. Now however, my god what a tank. Its huge and drives huge. I miss my vert.
08-01-2018, 01:24 AM | #38 |
Rep 20
Drives: 2018 440i grand coupe m sport
I’m currently running on mppsk + dinansports stage 1. At first i was satisfied with how smooth it ran and the increase in torque but didn’t see a consistent increase in whp. I would cap at 380 and then drop down back to 357-360. Looking into mission tuning stage 2, apparently they think they can get my 440 to hit 400 whp consistently on the dyno. We shall see !
08-02-2018, 11:11 AM | #39 |
Rep 296
Going to pick my car up today, been at the dealer this past week with a CEL.
They told me something about a faulty charge pressure sensor, I'll post back with specifics when I get the paperwork. |
08-06-2018, 08:30 AM | #40 |
Rep 296
Update:
Something is definitely up with my dinan stage 1. Sometimes the car feels lifeless and sometimes it feel great. I've noticed sometimes my app cannot find the dinan module and sometimes it can. I'm not getting any CEL lights. I think maybe there is something wrong with the dinan module itself, like sometimes it powers on and sometimes it does not. Not sure what to do but I will contact dinan today. |
08-09-2018, 09:01 PM | #41 |
Rep 192
Have stage 1, recently was towed to BMW because drivetrain malfunction. Initial though by service was the throttle body failed. Now they found metal shards in engine, so the engine will likely be replaced.
Get elite, not sport. The warranty helps. |
08-10-2018, 08:32 AM | #42 |
Rep 296
My car has returned to its normal self I believe.
Maybe the ECU needed to re-calibrate after being worked on, maybe it was bad gas, or maybe it was the 110 degree temperatures making it feel down on power. |
08-10-2018, 09:36 AM | #43 |
Rep 474
CELs have returned (last week july, first week august -- currently been on for 3 days now), this is tuner #3 (installed late May of 2018), having it removed from my vehicle, ... done with Dinan tuners, .... or tuners for that matter, back to stock, .... well, keeping my midpipe, exhaust, & suspension though, cause they rock and dont cause problems
Looking for 335/n54
