01-31-2019, 09:02 PM | #969 | |
Rep 318
I have trouble seeing how having no condensation forming at all in the air conditioning system for the 8 months a year I don't need it can be worse than having condensation form every time the air conditioner runs unnecessarily during those months and then having it run a dry cycle to remove it.
18 M240i RWD auto
Previous: 01 Z06, 99 323i |
02-01-2019, 08:35 AM | #970 | |
Rep 6,075
Given the minuscule, if even noticeable, effect of letting the system remain in AUTO all year, versus the downside of trying to out-think when it should operate, it seems more a personal philosophical concern ("it should be off") than a real-world practical need. What little I know came from learning from HVAC engineers at the car company where I spend a few decades in my pre-retirement career. It becomes a case of knowing one's limitations. If you have specific training or other expertise to know the effect of trying to only periodically manage excess humidity (using AUTO with compressor activity) in an environment where the off condition remains ambient humidity, above that of allowing periodic automatic drying, then you may have a case to make. I don't. I have had cars in the distant past where HVAC systems have developed the musty/rotten locker room odor, requiring significant intervention. With the possible downside of trying to fully clean/de-odorize the entire HVAC system, I can see no case for the benefit outweighing the risk.
02-01-2019, 08:55 AM | #971 |
Rep 1,219
Drives: 2015 M235ix
Climate is also an issue. If, like me, you live by the ocean, where, even today, at 17F, the relative humidity is 53%, and most if the time it is over 70%, then keeping the AC on makes sense. But albertw lives somewhere in Canada. If he is on the prairies, then it is much less humid than here most of the year, so for him it may make sense not to use the AC as a dehimidifier year-round, the way I do.
Everything is context-sensitive. |
02-01-2019, 09:53 AM | #972 | |
3718
Rep 3,625
I also live on the Canadian Prairies and leave the system on auto all year round to good effect, whether the temperature is +35°C or -35°C. Last edited by aerobod; 02-01-2019 at 10:06 AM.. |
02-01-2019, 10:00 AM | #973 |
Rep 6,075
This is exactly the point, it "may" or it may not, and the benefits of not using it are almost invisible, with the longer-term outcome to the HVAC system at risk for the foul odor problem. Why try to out-think a complex system/algorithm that was developed and tested across multiple continents/climates for no real gain? Sometimes, our need to be "in control" and think we know better results in negative outcomes.
02-01-2019, 03:23 PM | #974 |
Rep 318
Water vapor condenses on surfaces only if they are colder than ambient, even at near 100% humidity. It's hard to see the HVAC system being colder than ambient as long as the air conditioner compressor is OFF.
Fog is a different issue. It can be deposited on surfaces that move through it, or on the HVAC system as it's pulled through. Only heat will evaporate the water under these conditions. I doubt very much that the Germans are smart enough to design a system that knows it's foggy out, but I could be wrong. I would rather turn the heat on manually to keep the system dry in foggy conditions. Where I live it's never foggy and warm enough that I can't run a bit of heat. I've never tried the auto setting in this car, but every other car I've had did really annoying things with the fan speed and heat distribution in auto. I like a cool breeze on my face and warm air on the rest of my body. The auto setting always messed with that setup. Turning the fan to max for no reason is really annoying if the air hitting your face is cold. When I need the air conditioner, I turn it off and the fan to max 15 minutes before I stop, and I've never had a problem with HVAC odor since I started doing that. I suppose if I lived where the ambient temperature can be high enough that 15 minutes without air conditioning would be uncomfortable, or it was so humid that only heat would dry out the HVAC, I would try the auto setting, but I don't so I don't.
18 M240i RWD auto
02-01-2019, 10:06 PM | #976 |
Rep 243
Today went to pick up my clothes at the Dry Cleaner when looking for the hanger hook I found a little hook behind the driver side.
That hook is a far cry from any other hanger hook. Also noticed there is no "oh shit" handle bar where most hanger hook are located in other cars, usually on the passenger side.. |
02-02-2019, 03:49 PM | #977 | |
Rep 3,506
The clothes hook issue has a solution of a sort that can be seen on this page: https://www.shopbmwusa.com/ACCESSORI...AT-ACCESSORIES I don't know of a solution for the missing grab handle(s). I suppose if an owner felt a strong enough need for one, a body shop or a fabrication shop might be able to come up with a solution that looked satisfactory.
02-02-2019, 03:58 PM | #978 |
3718
Rep 3,625
The seat width adjustment can hold the passenger and driver in place in the seats, so less of a need for a grab handle to steady the upper body in hard cornering.
02-02-2019, 05:41 PM | #979 |
Rep 1,219
Drives: 2015 M235ix
Clothes hook: I bought two little universal hooks that go over the post of the headrest, one in each of our cars. Total cost about ten bucks. Totally worth it!
02-02-2019, 08:58 PM | #980 | |
Rep 100
02-02-2019, 10:48 PM | #981 |
Rep 12
While we're talking about climate control - do we still need to turn off HVAC a few minutes before reaching destination to prevent any smell from condensation, even if it's in auto mode with A/C on at all times?
02-03-2019, 08:25 AM | #983 | |||
Rep 326
It took some discipline not to futz around with the climate control and even more to convince my wife to do the same! But yes, the engineering really works and we have remained comfortable under a variety of conditions without playing with buttons. Only the center knob gets twiddled for fine tuning and for control freak nostalgia.
Retired: '08 335xi E90. "Long may you run."
Retired: '19 M240xi "You also" |
02-03-2019, 12:58 PM | #984 |
Rep 318
Since it looks like the "Auto" fanboys are never going to shut up, it's worth repeating that this part of their argument is absolute and total nonsense.
Makes you wonder about the rest of their message, if they can't even understand how condensation happens.
18 M240i RWD auto
02-03-2019, 12:59 PM | #985 | ||||
Rep 314
It took some time, coming from a basic Honda HVAC system, but I've learned that this one operates much like one in a home. It's goal is to make the environment the requested temperature, not to make the expelled vent air the requested temperature. Patients is key when wanting a different temperature overall, but with practice, you can have temporary satisfaction by modifying the degree dial. |
02-03-2019, 01:48 PM | #986 |
Rep 1,219
Drives: 2015 M235ix
Fans of the little wheel in the middle that adjusts the relative temperature of the center vents may have need for concern. In the last month, I have had two 2019 loaners, an X2 and and X3. Neither had the little wheel!
02-03-2019, 03:35 PM | #987 |
Rep 6,075
I'm not going to descend to name-calling or venom. You're entitled to your skepticism. All points have been made and readers here can decide whether to believe any of us anonymous forum posters or rely on using their car in the manner BMW engineered it.
dradernh4473.00 |
02-03-2019, 05:59 PM | #988 | |
Rep 318
1. The owners manual for my car describes both manual and automatic operation. I just reread the section to confirm that there is no recommendation for either. 2. My owners manual says nothing about a system that automatically dries the HVAC system after the engine is turned off. Maybe such a system exists, but the only evidence I have for that is "anonymous forum posters". 3. This model hasn't been out long enough that anyone can know that over my target ownership of 10 years the automatic drying system, if it exists, works as well as properly using the manual settings to dry out the system before turning off the engine.
18 M240i RWD auto
02-04-2019, 08:40 AM | #989 |
Rep 1,219
Drives: 2015 M235ix
This particular model has only been around for six model years but I doubt that any aspect of the A/C is unique to it.
Some of us like the luxury of not having to adjust the climate control. Set it and forget it! Others prefer to do it themselves. Neither side appears to be harming anyone. Let's call it a draw. |
02-04-2019, 10:16 AM | #990 | |
Rep 100
