2Addicts | BMW 2-Series forum BIMMERPOST Universal Forums General BMW News and Cars Discussion BMW Recalls 156,137 Cars for VANOS Bolts Issue (2010-2012 6 cylinder models)
      08-25-2014, 03:35 PM   #133
Tony135
Drives: ‘22 Model 3
Any update on American dealers? My car is starting to act reallllllly bad.
      08-25-2014, 03:43 PM   #134
2011CrazE89
Moved on
2011CrazE89's Avatar
Drives: 2011 Z430i & 2015 MB C300
I got my card notifying me of the recall a month ago. Still no update on parts availability.
      08-25-2014, 04:50 PM   #135
ze_german
Autobahn Addict
ze_german's Avatar
Drives: '11 E92 N55 6MT Msport
If your car is acting really bad you have to bring it in immediately. At least that's what the letter said.
What exactly is the car doing?
defi boost gauge in custom 3d printed pod, jb4, bms cdv/cs, er cp, vrsf 7" ic, m3/poly diff/tranny mounts, st coilovers, cyba 3.8 tips
      08-25-2014, 04:53 PM   #136
Tony135
Drives: ‘22 Model 3
Starting to stall a lot but what scares me the most is on the freeway, the engine will start stuttering and cut power. It's doing it every couple of days now and its to the point where I can't even drive while it's doing it.
      08-25-2014, 05:05 PM   #137
ze_german
Autobahn Addict
ze_german's Avatar
I would def call the dealer and bring it in, or at least have the codes checked asap. Could be the fuel pump too come to think of it.
      08-26-2014, 04:16 PM   #138
Tony135
Drives: ‘22 Model 3
Would there be any tell tale signs of the fuel pump going out? I know on my old Audi the fuel pump would whine a bit.
      08-26-2014, 05:35 PM   #139
ze_german
Autobahn Addict
ze_german's Avatar
Exactly what you are describing actually. Stalling, cutting power.
Afaik on our platform it's the high pressure fuel pump that has problems.
You need to have the codes read.
      08-26-2014, 10:23 PM   #140
GB-335xiCoupe
Libertarian
GB-335xiCoupe's Avatar
Drives: 29k mi per year.
Long starts is also a symptom of the hpfp failing...
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi
Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k
Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k
      09-24-2014, 04:25 PM   #141
SigsMeister
SigsMeister's Avatar
Drives: 2012 135i Blue/Tan Nav/M/HK
Mine is at the bmw dealer currently getting fixed, but the parts appear to be delayed (Southern California).
Anyone out there that has actually had the VANOS recall done?
      09-24-2014, 06:09 PM   #142
ze_german
Autobahn Addict
ze_german's Avatar
I called Crevier about 2 weeks ago and they told me they had no parts to fix it. If I wanted I could try BMWNA but atm there is nothing going on.
Did you receive the letter to come in or did you go yourself?
      09-24-2014, 09:33 PM   #143
SigsMeister
I took it in to the dealer for service and they said they could take care of the recall as well. Just heard it will be ready tomorrow and getting the engine timed as well since it has to do with the valves.
      09-25-2014, 11:11 AM   #144
SigsMeister
WOW just got my car after the recall, with the engine re-time, the engine feels brand new, less turbo lag, super smooth, haven't taken it for a "real" ride yet, but so far, big smile
      09-25-2014, 11:35 AM   #145
ze_german
Autobahn Addict
ze_german's Avatar
I wonder what they mean by 're-time'. AFAIK the dealer updates the car to the latest software and the VANOS bolts are just replaced, there is no re-timing of anything.
Which dealer did you go to?
      09-25-2014, 02:39 PM   #146
SigsMeister
Irvine. Maybe it was done out of courtesy? ... either way I'm quite happy :-D
