2Addicts | BMW 2-Series forum Technical Topics Tracking / Autocrossing M235i track tool. Heating problem...
      09-13-2023, 03:28 AM   #1
Hooczek
Lightbulb M235i track tool. Heating problem...
Hi
I'm building a track tool from my M235i. I have modified it a little
There is a Vagner EVOII intercooler, DO88 water cooler, additional CSF oil cooler, mosselman oil thermostat, AFE intake, aluminum hoses, complete exhaust with downpipe and many mooooore.
I still have problems with the temperature. Oil gets too hot on the track (140⁰C) nad water temperature goes up to 112⁰C. Transmission also is reporting high temperature.
I'm thinking about changing oil cooler for a larger and put new hoses. OEM pipes are little to thick I think. I was also thinking about new cooler mounted in the fender. The OEM mounted on the radiator is too small.
What do you think?
Name:  2023-08-23 20.07.34.jpg
Name:  Gotowe - 2O7A8874.jpg
      09-13-2023, 08:51 AM   #2
AmuroRay
AmuroRay's Avatar
2283
CSF oil cooler is garbage - go with something bigger and better. I would also consider changing that intercooler. The Evo 2 is one of the worst track intercoolers out there.
Mods: Yes.
      09-13-2023, 12:58 PM   #3
Hooczek
Thanks. I will get rid of it. Why EVO2 is the worst? I don't see a problem with it
      09-13-2023, 06:36 PM   #4
jb-slow
Drives: m235i
The oil temp is a bit high, but the water temp is the same as driving in traffic on a warm day, no-issue there. I have all the same cooling stuff you have and haven't gotten the oil that high ever on track, is your heat exchanger plugged up or something?
      09-19-2023, 01:17 PM   #5
AmuroRay
AmuroRay's Avatar
2283
Do you have any logs to show us? For almost everyone, the Evo 2 is about 60F+ over ambient, so it isn't doing much.
At a minimum, you'll need to run MAX COOL settings on BM3 or MHD, consider converting to water + water wetter for the coolant, upgrade the oil cooler (ER makes a unit, but you might want to see what's offered on your side of the world. The CSF unit is barely better than stock.)
Mods: Yes.
