12-21-2015, 04:33 PM | #1 |
Rep 264
Tips & Tricks
Are there any tips & tricks thread for the 2-series / BMW in general? I tried to search but doesn't seem to exist.
One useful feature i found was tapping the seat slider button to have it automatically slide back and forth instead of holding down the button (my CA didn't even know this). |
12-22-2015, 02:27 PM | #2 |
Rep 351
there's a sort of launch control. clutch in, press the gas, revs will stop around 3-3.5k. let out the clutch and away you go. still unsure as to if this is launch control or a rev limiter...
or, if you have an auto I don't know how that works haha |
12-22-2015, 02:40 PM | #3 |
Rep 8,942
You can also go in settings so comfort access unlocks all doors, not just drivers.
12-22-2015, 02:49 PM | #4 |
Rep 5,577
The belly pan panels are kind of ingenious in that they don't flop down when you loosen the fasteners, but need to be shifted so you can then have both hands free to drop it. I'm coming from a Benz that flopped open so the BMW way is better.
12-22-2015, 03:01 PM | #5 |
Rep 119
Drives: 2014 M235i EBII May '14 ED
If you have the technology package with gps, you can assign one of the preset buttons for navigation to set a route to home
It's nice to simply press one button wherever I am when I'm out and about, and know the way home a few seconds later. |
12-22-2015, 03:23 PM | #6 | |
Rep 144
12-22-2015, 03:31 PM | #7 |
Bright Sky
1165
Rep 922
Drives: BMW M235i (8AT)
Curious about this as well!
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. |
12-22-2015, 03:35 PM | #8 |
Rep 855
12-22-2015, 03:35 PM | #9 | ||
Rep 119
12-22-2015, 03:38 PM | #10 | |||
Rep 144
12-22-2015, 03:48 PM | #11 |
Bright Sky
1165
Rep 922
Thanks! Much appreciated!
12-22-2015, 08:05 PM | #12 |
Rep 818
It works the same for saving any "shortcut"
Highlight what you want a shortcut to and press & hold your designated button. For your home address just go to your "recent destinations" and highlight your home address. Press & hold number. I have 1-3 phone numbers, 3 as control display brightness, 4 as TPMS, and 8 as my home address |
12-22-2015, 09:44 PM | #13 |
Rep 264
Thanks will definitely need to try this.
12-22-2015, 10:52 PM | #14 |
Enthusiast
692
Rep 340
Currently Drives: 2023 Porsche 718 Cayman
12-24-2015, 09:40 AM | #16 |
Cone Killer
85
Rep 208
If you lightly rest your finger on the pre-set buttons (not hard enough to press it) you will see a description of what that button is programmed for on the display.
12-24-2015, 02:32 PM | #17 |
Rep 1,753
If you have a manual transmission your car has hill assist. When on a hill after you take your foot off of the brakes the car will hold the brakes for a second giving you a chance to get going without rolling backwards.
12-24-2015, 03:49 PM | #18 |
Rep 361
12-25-2015, 09:12 AM | #19 |
NewFinishColumbia/detailer
604
Rep 2,096
The preset buttons are great. I use them for quick shortcuts to settings like the lights and trip computer info. I also use them for a couple radio presets as well.
I haven't heard of the launch control with the manual trans. I will have to give that one a go once the weather isn't wet. Is there a certain configuration your settings all have to be in before you can use this? If you want the sport sound for the exhaust (flap open) you can start the car, let it warm up, put it in Sport, rev up above 3K while shutting off the engine. Go under the driver's side and unplug the flap control connector, start the car back up and make sure that there is air coming out of both pipes. Shut the car off and use electrical tape to tape up the connector ends and tuck the wire up there behind itself so it's dangling around. Bingo! Sport exhaust all the time.
12-25-2015, 10:30 AM | #20 | |
Rep 1,797
FWIW, my buddy who works in the professional and personal security world advised us to not put the actual home address in car. Just a zip code or town instead.
Previous Rides: 535xi, M235xi, X3, E92 M3, E70 X5 35d, X6 50i, X6 35i, E60 550i, E46 M3 Cabriolet, E39 540i, E36 328i
12-25-2015, 01:00 PM | #21 | ||
Rep 818
A lot of people say this but I think there are easier ways to get someone's address if they wanted it that bad. |
12-25-2015, 01:22 PM | #22 | |||
Rep 8,942
