2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning WARNING!!! JB4 can damage your DME/ECU if handeled improperly
      05-14-2015, 08:57 PM   #1
harkes
harkes's Avatar
China
1075
Drives: M135i, E39 M5, NSX and AE86
To all current owners of a JB4!
The JB4 installation manual has been updated with the following warning:
"Also be very careful when working with the BMS USB cable as it sits close to the battery rail which is a live +12v connection. Allowing the USB cable to touch the +12v connection WILL damage the JB4 and MAY damage the TMAP sensor wiring requiring the ground bypass at the bottom of the guide to be performed. Wrapping a piece of cloth tape over the battery rail connection and/or USB connection will help prevent accidental damage"
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China)
      05-14-2015, 10:29 PM   #2
alz0rz
What goes here?
alz0rz's Avatar
450
Drives: 2019 G30 M550i
This has been a known problem for the longest.... This is not unique to the JB4... just don't short the positive terminal... No need for such an alarming post.
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
      05-14-2015, 10:46 PM   #3
harkes
harkes's Avatar
China
1075
If this alarming post can prevent just ONE other person from the same fate as me - then there is a very good need for it.
I am a hobby tuner so don't expect me to know a USB cable can cause this much damage. Back in July 2014 when I installed my JB4 this was not highlighted as a risk.
(A Dane in China)
      05-18-2015, 02:55 PM   #4
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
It's my understand that this will basically blow the ground on the tmap sensor but wasn't aware of actual DME damage as a result. Will keep in mind.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010
The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35
      05-19-2015, 10:54 AM   #5
JibHonk
Drives: 15 m235i
Breaking! Smoking Cigarettes Can Cause Cancer!
      05-19-2015, 10:59 AM   #6
qballis
Drives: G80 Comp xdrive
WARNING!!!!! A hammer can break your windshield!!!
      05-19-2015, 08:41 PM   #7
harkes
harkes's Avatar
China
1075
The TMAP ground trace in question is on the DME board so if you ask BMW to repair it for you they will replace the complete DME.
(A Dane in China)
      05-19-2015, 09:28 PM   #8
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
Gotcha. Thanks for the clarification!
Follow my builds:
Search this Thread:
