06-14-2018, 02:09 PM | #1 |
Rep 980
Very slight off-center steering bias: what to do?
Gents, I'd appreciate your advice. I have always sensed a very slight rightward bias in the steering wheel position (i.e. it's at 12:03 instead of 12:00 when tracking straight). It's not a huge deal but I was hoping that the alignment done at the dealership yesterday when I got four new PSSes would fix it; it hasn't.
I'm not sure I want to take it to my tuner for another (probably more expert) alignment. I wonder if there is a "one click" solution, i.e. some adjustment that can be made in five minutes; it's an electronic steering rack after all. The steering ratio seems very finely calibrated to me, so it's not like a quarter-inch offset has any practical effect on the car's tracking but like a lot of you, when it comes to my cars, I can be somewhat OCD. Any suggestions? Many thanks.
2015 BMW 228i M Sport w/Track Handling Package DAP | Lighting | Premium | Tech DINANTRONICS Performance Tuner Stage 1 | DINAN Shockware | DINAN Free Flow Exhaust | DINAN Performance Spring Set + Ride Quality and Handling Kit |
06-14-2018, 02:11 PM | #2 | |
Rep 555
06-14-2018, 02:16 PM | #3 |
Rep 980
Yeah, plus my right hand rests a tiny bit lower on the wheel but still...
06-14-2018, 03:32 PM | #5 |
Rep 980
I thought about that but the offset does not seem to vary on very crowned roads vs. flat.
06-14-2018, 03:53 PM | #6 |
Rep 8,942
I could be wrong but I thought I read somewhere that cars are set up with a slight bias away from oncoming traffic so specific to the location the car is sold in. Reason being if you fall asleep or have a stroke or something while driving drifting away from oncoming cars is preferable to into them.
06-14-2018, 04:08 PM | #7 |
Rep 6,029
As your post suggests the car does track straight, the alignment specs are likely correct. I’d visit the dealer and respectfully suggest that they didn’t have the steering wheel straight when those correct specs were set. That should be remedied by them having you agree the wheel is straight when the car is on the rack and then re-setting the original correct specs. I’ve been through this before.
BEM-S44515.50 |
06-14-2018, 04:10 PM | #8 | |
Rep 8,942
Pulling the wheel you can break all kinds of shit, definitely have the shop do it since this would be a no cost repair.
06-14-2018, 05:56 PM | #9 |
Rep 318
This is a fairly common problem after an alignment. Some techs aren't quite as concerned about getting the steering wheel positioned exactly right as some drivers are about it.
I haven't had a look at my M240i, but on every car I've owned this was an easy fix. The front wheels are turned by rods that come out of the steering rack. There is an obvious way to adjust the length of those rods. If you make exactly the same adjustment on both sides (shorten one the same number of turns as you lengthen the other), you don't affect the alignment at all. The only thing you change is where the steering wheel is turned for a given position of the wheels. The easiest way to think of this is that when your steering wheel is set for perfectly straight ahead the wheels are actually turned a bit to the left. You adjust the length of the rods to turn both wheels slightly to the right. For the discrepancy you see, a couple flats (1/3 of a turn) would be a good place to start. Look carefully at the threads to make sure you know which way to turn to get the length change you want. Use how hard it was to loosen the lock nuts as a guide to how hard to tighten them. It would be a good idea to mark the orientation of the rods before loosening the lock nuts in case you turn a rod at the same time, and also to let you check that you turned each one in the correct direction and turned both the same amount. (My understanding is that the steering is assisted by an electric motor, but the connection to the wheels is still mechanical. Only one of the Infinities has a fully electric steering system. If I'm wrong about this ignore what I wrote.)
18 M240i RWD auto
Previous: 01 Z06, 99 323i Last edited by albertw; 06-14-2018 at 06:08 PM.. |
06-14-2018, 06:15 PM | #10 | |
Rep 980
No pulling involved; the offset is very small.
06-14-2018, 06:49 PM | #11 | |
Rep 980
06-14-2018, 07:24 PM | #12 | |
Rep 59
They should have fixed it when doing the alignment and the alignment comes with a warranty so if you demonstrate the problem the dealer should be able to fix it. Did you mention the steering offset problem when dropping it off for the alignment? |
06-14-2018, 08:01 PM | #13 | |
Rep 744
