10-01-2012, 02:45 PM | #24 |
Rep 7,047
This is an amusing review.
A BMW 3 series wins, NOT because of it's handling and fun to drive factors, but because of an interior design opinion. I recall the 3 winning many times even when iDrive was considered the worst of it's kind. My, times surely have changed. I'm amazed at how negative he is towards the handling on backroads even with a sport line 328i that has the sport suspension. My 335i Msport has the M adaptive suspension, and I don't know if it's really that much stiffer or better in "sport" mode as the standard sport suspension. But, I was down in southern Indiana around Bloomington last week and the handling and control were excellent with my 335i. Yes, it could use a bit firmer spring, or thicker sways, but over all there is no way I would describe it as not having "an ease" about how it's does things. In this review he pretty much makes the 328i sport line sound pretty bad when being driven as a sport sedan on twisty imperfect roads. Is the adaptive suspension that much better than the standard sport suspension? From his description the 328i sport is as lackluster as any other car compared to a 3 series, when you compare the 328i to the ATS with it's magnetic ride control. It almost sounds as if he's not driving a sport line, but maybe a Lux or Modern with the standard suspension. If the sport suspension garners those types of comments, then the Lux and Modern may be no better than an Accord or Camry. But then, he picks the 328i as the winner?! WTF? He sounds confused. |
10-01-2012, 03:10 PM | #25 | |
Rep 1,268
It's a sad day to see a Cadillac handles better than a BMW. Or any GM for that matter. CD picked the Camaro ZL1 over the M6 conv. and the 3er won against the ATS, to me, over being biased. Let's hope the ///M335i and ///M3 are leaps and bounds better than the standard sport line ///M sport.
Past: BMW (22 G20 M340i, 15 F80 ///M3, 12 E92 335i, 08 E90 335i, 02 E46 325i)
Mercedes-Benz, Porsche, VW, Lexus Present: 24 992 C2 |
10-01-2012, 03:17 PM | #26 | |
Rep 7,047
The only reason he picked the 328i is because of it's interior design, and because it's of greater quality, but because the driver/reviewer preferred the F30's design. Yet all that is personal preference really. I like the ATS's interior design. I more prefer the F30's exterior. |
10-01-2012, 03:36 PM | #27 |
Rep 176
Drives: BMW
I think the ATS is a great car and it will only make the 3 series better. One of my biggest issues with it is the CUE system, as was pointed out in the review. When will the American car manufacturers realize that touch screens in a car are an awful idea? Yes, they are very cool and work very well when you are not moving. However, as soon as you begin driving, it is impossible to select anything you want without taking your eyes off of the road, and even then it is difficult. I say this from experience with another GM nav/audio/climate system. In my mind, when you combine these basic functions into a touch screen, it disqualifies the car for me. I don't care how well it drives or how fun it is, if I can't reach over and turn the a/c on without taking my eyes off the road for 5 seconds, I will not buy it. Even as a passenger, I have found the GM touch screens frustrating and difficult to use. The iDrive is reason alone to buy the BMW.
10-01-2012, 03:42 PM | #28 | |
Rep 193
10-01-2012, 03:47 PM | #29 |
Rep 7,047
The reviewer of the ATS says "with the performance packages adjustable shock absorbers...".
But the problem is that the ATS 2.0 'Performance' variant does not come with the adjustable magnetic suspension. On Cadillacs website, the ATS 2.0 Performance model doesn't even show the adjustable suspension as an option. It shows the 2.0 Performance model as having a "sport suspension", and the magnetic system has an "X" showing it's not even available on that model. To get the magnetic system and "performance" suspension you have to step up to the next model the "2.0 Premium", but it costs more than the MSRP shown for the ATS tested here. So, what gives? Also, part of the cost when opting for the manual trans, includes the addition of a mechanical LSD. That LSD is standard in the 2.0T Premium pkg, and you can have LSD with auto trans with that pkg. Seems that either they are using the higher cost 2.0 Premium ATS, which includes magnetic dampers and the "performance" suspension, or the ATS used is a 2.0 Performance ATS that uses the standard non-magnetic damper sport suspension. If it is the standard sport suspension, then the ATS chassis and no adaptive suspension is even better than even the reviewers thought. The "FE3" option includes the magnetic dampers, but that system is not shown on Cadillacs options list. |
10-01-2012, 03:47 PM | #30 |
Rep 300
my 300C SRT8 came with 245's all around and I have 2x the power of a 328i. It does have a rear diff though, which makes a LOT of difference.
| '13 328i M Sport - Estoril Blue | '12 300C SRT8 | '12 Wrangler Rubi Unlimited - COD MW3 Edition|
10-01-2012, 04:18 PM | #31 |
Rep 223
The ATS 2.0T manual comes with LSD standard. The auto needs magnetic ride control (MRC) suspension (FE3) to get LSD.
If the test car was in fact a Performance trim, it had LSD and standard sport suspension (FE2), not MRC. The suspension can still be adjusted, softer in touring mode, stiff in sport mode. In sport mode the FE2 suspension was too stiff. But in touring mode, the suspension controlled the body just as well, only the throttle was much less aggressive. Yes the ATS chassis was amazing, nothing like it in this segment. I drove the 3.6, exhaust was also fantastic. The engine was less refined than the 3 series for sure. The latest Insideline tested the same two cars. The F30 328i had better 0-60 (by 0.3s) and 1/4 mile, but the ATS had better slalom speed, skid pad lateral g, braking distance, and get this, better steering. |
10-01-2012, 05:08 PM | #33 |
Rep 562
Drives: 2011 1M VO
Just drove the ATS at the Autobahn in Joliet IL at Caddy-sponsored event and I was VERY impressed. These were 3.6 with magnetic suspension and black interiors. Braking, handling and motor, in that order, were all pretty impressive despite the autobox. Call me a rube, but I was even impressed with the interior, but making it black probably helped cut down on the chaos that C&D complained about; I am sure I would hate the CUE, tho, as I still don't like ANY built-in NAV systems. I am very hopeful that Caddy can claw its way back to world class.
10-01-2012, 05:51 PM | #34 | |
Rep 399
Drives: '15 M3
It's not as simple as stating that he chose the Bimmer because of his perceived impressions of the interior quality. That was 1 data point amongst other items. |
10-01-2012, 06:37 PM | #35 |
Rep 270
Is it just me or did the 328 remind you of a late model mitsubishi lancer? The way that the grill and headlights flow together.
I for one love the interior, but the base model front fascia is a bit odd. Throw on a M-Sport package and all is well. I look forward to the LCI update. The ATS is hot on their heels. With their magnetic suspension technology and vast engine package, they're only a few years away from surpassing them. I look forward to seeing how they compete!
Sakhir Orange M4||()
10-01-2012, 08:37 PM | #36 | |||
Rep 295
I think Cadillac might've made a mistake in naming their Collections. The Premium should've been called "Performance" as it includes the performance options such as the performance suspension, MRC and LSD. |
10-01-2012, 09:00 PM | #38 | |
Rep 7,047
But that brings up the question, did Cadillac over state the HP/torque rating on this engine? If so, then how are they going to fix it? Interestingly, I did a search in the Chicago area for an ATS 2.0. I searched about 5 or 6 dealers and none of them had even a single 2.0 ATS. There are more dealers, but I was very surprised that I couldn't even find one 2.0 and Cadillac expects the 2.0 to account for I think 50% of it's sales. I wonder if Cadillac stopped 2.0 sales and/or pulled stock, and are looking into the power to performance disparity? Cadillac claims to have more HP and torque compared to BMW's stated numbers. BMW's numbers have been confirmed as actually being greater that what is claimed. If Caddy's numbers don't hold up, they may have a problem like Ford did with one of it's Mustang Cobra's, and Mazda's issue with the RX8 not producing the stated power. Anyone find any ATS 2.0's in their area? |
10-01-2012, 09:13 PM | #39 | |
Rep 7,047
After all, after stating how much better the ATS was in terms of all around performance and handling, the subtle things you mention can't elevate a car to be the 'winner'. A not so great shifter and a bit coarser engine at high rpm is hardly a loser when it has better handling, better ride, better steering and feel, better braking, etc..., and the 3 has a nicer interior and better iDrive. Remember, when iDrive first came out, nearly all the mags C&D included hated it, but they never knocked the 3 series below 1st place because of it, which was due to it's superior chassis and handling. That's how I took it after watching it a couple of times. I'll watch a couple more and look and listen again. As I said, the rules seem to have changed now that the King is being greatly challenged. |
10-01-2012, 09:16 PM | #40 | ||
Rep 4,668
Drives: BMW
If the ATS is judged similarly to how the 3-Series did to win all those comparisons, I think the ATS should win. - iDrive was pretty crappy at first but BMW still won the comparisons. - Audi/Mercedes arguably way better interior with OK handling. BMW has a cold feeling interior, great handling. BMW wins comparison. Everything the media said about Audi and Mercedes when BMW were raking all those wins, BMW is now receiving those exact criticisms yet they're still first? Quote:
10-01-2012, 09:19 PM | #41 | |
Rep 7,047
I bring up the options and model because they list the "as tested" MSRP for the ATS. If it is a "Premium" model, then the MSRP is higher. IF that is the case, the review states the wrong information. But as a poster pointed out, that ATS may not have, and likely doesn't have the FE3, as it's not an option no the "Performance" ATS. Just wanting to clear up the info. I don't think Caddy made a mistake, the review video doesn't give enough information, so we're left to guess. |
10-01-2012, 10:07 PM | #42 |
Rep 1,914
10-01-2012, 10:09 PM | #43 |
Rep 2,400
Funny how Cadillac in designing the ATS used the E46 as the "dynamic benchmark" and the E90 as the dimensional/size benchmark. Even the competition believes the best "feeling" BMWs were from 1-2 generations ago. Having recently driven a new 328, the car is definitely less fun to drive vs my old E46 330i, particularly in the twistys, however the ride is smoother. Once a car gets beyond a certain size, it will lose a certain degree of "fun to drive" factor...there is simply no free lunch when it comes to driving dynamics. Think the E90 was right on the cusp of (and probably slightly over) that perfect size.
10-01-2012, 10:22 PM | #44 | |
Rep 5,803
F30 330i Alpine white/Coral red Msport 6MT
