03-20-2019, 04:25 PM | #199 | |
Rep 525
Swapping over to higher temp brake fluid certainly helps but doesn't make up for the lack of stopping power and heat resistance. Of course, if you're not really pushing the car on the track at all, just the fluid alone might be enough but highly doubtful that many enthusiasts (even if they don't track) will be satisfied with OE pads. With that said, it really sounds like you don't do a whole lot of tracking so you wouldn't need a dedicated set of track pads, but I would also stray away from OE pads so you can get a bit more performance out of it. Since you want to minimize pad swaps, look into those that can handle some track abuse without being a full blown track pad. I'm a big fan of Hawk pads for their performance to price ratio and operating temperature; I recommend you look into HPS 5.0 (mostly street), HP Plus (mix street/track), or Street Race (more track). HP Plus and above should be able take anything you throw at it but will be quite noisy and dusty. Keep in mind that more capable pads tend to dust more and be noisy so if that's of higher priority then just know you'll have to sacrifice performance. |
03-20-2019, 07:58 PM | #200 |
Rep 1,241
Thank you, cpx! Dust is not a concern of mine. Even OEM pads create dust. The way I see it, either the wheels are freshly washed and clean, or they are dusty. Don't care how fast it happens, really.
I think something like the Hawk HP Plus (mix street/track) type of pad makes sense for my needs, but I'd like to hear about first hand experiences in terms of squeal and operating range on the street. Any other brands offering an ideal mixed street/track pad that someone can comment on from 1st hand experience? Out of curiosity, has anyone out there pushed the BMW M Sport OEM pads on track to the point where there was an issue with wear, glazing, etc.? I'd just like to know what to expect should I choose to take the OEM pads out there on the track. If I'm going to melt them and glaze my rotors like I did with the WRX, then I'll just upgrade the pads immediately. Otherwise, if I'm just looking at accelerated wear and less stopping power, I can live with that. Thanks again!
CP911
03-21-2019, 12:06 AM | #201 | |
Rep 51
I've ran OE Pads and rotors at a track. They were OK for few laps, 7' 8', then pedal was less firm and there was some glazing/coloring of rotors/possible pad material transfer. Since then have switched over to Powerstop drilled rotors and Powerstop PST 1609 track pads, and been satisfied with them. Great value for money as a 2nd set (+) have taken some abuse (+) repeatable stopping power (-) cold friction is lower than OE for street use. Also running some HP Plus on an E90. (-) major squeal during daily use - not running shims or grease though (-) dusting, and gets everywhere on the car (+) stopping power equal or better than PST 1609 (+) can take track abuse. (-) Cold friction is less than OE. The Powerstop set-up seems to do well as a dual purpose setup, at these ambients of 15+C; and no squeal; and average dusting (maybe less than OE) Though car is not a daily, I'd say the OE pads are OK for 7/10ths 8/10ths track driving, but they don't build confidence as speeds improve. Dedicated tracks get better with heat - within their operating range.
BMW CCA Member
2017 BMW UDE Finalist rides : 2004 E46 M3 6MT (sold), 2011 E90 335d (daily), 2014 F22 Last edited by m3driver999; 03-21-2019 at 12:15 AM.. |
CP911986.50 |
03-21-2019, 12:18 AM | #202 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
CP911986.50 |
03-21-2019, 09:51 AM | #203 |
Rep 525
Hard pass on the Ferodo DS2500. I was told that exact same thing and found out the hard way. You get less stopping power, just slightly less dust, and less heat resistance. HP Plus stops significantly better, and for cheaper I think, but Ferodos are much quieter so there's that.
CP911986.50 |
03-21-2019, 09:08 PM | #204 |
Rep 1,241
Good discussion all! Really appreciate your input. Sounds like the PST1609 is the best of those 3 being mentioned, based on my needs anyway. I'd still love to learn more about other options out there. If price is not a concern, is there something out there that is considered more premium that can "do it all" i.e. street + track with no real downsides?
CP911
03-21-2019, 11:03 PM | #205 | |
Rep 1,931
no, look at snow tires, really good in snow, but wrong compound for summer. pads are same, you can't have a high performance pad that does not leave dust. You cannot run a race pad without sounding like a garbage truck/ school bus. The ebc yellow pads are my go to for street with little track use, its perfect for a auto x, but on a real track day they still will fade a little. Pads are nothing without a fluid change, and while your at it, change your lines.
www.nybmwcca.org
CP911986.50 Taskmaster2465.00 |
03-22-2019, 02:26 PM | #206 |
Rep 525
EBC Yellows are not meant to be used as track pads and even the Blues (EBC's "track" pads) can't keep up with HP Plus (mix pad). EBC Yellows are like StopTech Streets or Hawk HPS or Ferodo DS2500 -- they're all about the same and not much better than decent OEM pads.
Taskmaster2465.00 |
03-22-2019, 07:49 PM | #207 | |
Rep 5,262
They are very good on the street too so you can drive all year around if you wanted too.... you might get some squealing if you don't use enough brake pad grease on the backing plate and contact points |
03-24-2019, 08:22 PM | #208 |
Rep 1,241
Has anyone else noticed the Powerstop PST-1609 pads as recommended above by m3driver999 have the same model number "1609" (and "1656" for the rear pads) as Performance Friction's "M Sport Performance" 1609 and 1656 pads? What is going on here? Is one company just OEM'ing the other's pad? Both are being advertised as Carbon-Metallic compounds for Track Day/HPDE use, but the PFC pads seem to come in two compounds: "08" and "11". Can anyone shed some more light on these pads?
CP911
Taskmaster2465.00 |
03-25-2019, 07:26 AM | #209 | |
Rep 2,873
CP911986.50 |
03-25-2019, 09:55 AM | #210 |
Rep 1,241
How about rotors? Can the OEM M sport rotors take abuse from high-performance track or "race" pads? I know there are fancy drilled/slotted rotors out there, but do these just help with stopping power/bite or are they built with a certain type of steel that is meant to last longer and take the abuse from more aggressive pads?
Thanks again!
CP911
03-25-2019, 12:40 PM | #211 |
Rep 1,931
I used to get the oem bmw drilled and slotted , they were like 1200$ for a set.
I did that twice and was like F this, lets try the cheaper options. Stoptech's were great. I think fcp euro sells the OEM m perf rotors that fit the blue brakes. If so, lifetime warranty.
www.nybmwcca.org
03-25-2019, 12:52 PM | #212 | |
Rep 370
03-25-2019, 12:58 PM | #213 |
Rep 2,873
OEM rotors should be fine for track work; supposedly the plain flat (internally vented) rotors are best for this. Advice I've gotten is to avoid the drilled b/c the holes turn into areas for stress risers (until you get up into the $500/wheel variety). Slotted ones are supposed to increase brake pad wear w/o much improvement, but some feel they help in some ways. And definitely consider fcpeuro for that lifetime replacement, if they have what you want.
03-25-2019, 01:49 PM | #214 | |
Rep 1,241
CP911
03-25-2019, 06:18 PM | #215 | |
Rep 3,497
https://www.brakeandfrontend.com/fms...than-60-years/ Below is some data I pulled from the current Hawk Performance catalog (I used Hawk because I use their pads and had the catalog PDF handy). The left-hand image shows Hawk's catalog entries for the two FMSI numbers that are used in the F22 MSport brake calipers, front and rear. The right-hand image shows lists of Hawk's pad compounds, along with how they construct a product code for a specific pad. You asked about PF08 and PF11. Those are a couple of motorsport compounds from Performance Friction. Catalogs from both Hawk and PFC (Performance Friction) can be found at their respective websites. PFC's catalog details the applications for the two pad compounds. If you're going to get into track pads, I think it's worthwhile knowing your way around the manufacturers' catalogs. A qualified retailer that specializes in BMWs is a good resource, too. I recommend Bimmerworld - there are others, as well. For example, you may not be able to tell from reading PFC's catalog whether you'd prefer the PF08 or the PF11. A qualified retailer should be able to help you determine which is right for your use. At the bottom are a couple of images from Hawk and Ferodo showing useful data regarding some of their compounds. It would be nice for us if every pad manufacturer produced data like this.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF Last edited by dradernh; 04-01-2019 at 08:15 AM.. |
03-25-2019, 06:34 PM | #216 | |
Rep 3,497
It wouldn't hurt to check your rotors' remaining thickness with a micrometer from time-to-time. The minimum thickness is stamped on the rotors' edges. That data is also in the shop manual: https://www.newtis.info/tisv2/a/en/f...kes/1VnYODanTi FWIW, along with the pad compound you choose, how you use the brakes at the track will have quite a bit to do with how quickly you wear the rotors.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF Last edited by dradernh; 04-01-2019 at 08:17 AM.. |
CP911986.50 |
03-27-2019, 04:50 PM | #217 |
Rep 3,497
If you're going to the track, I think you're a good candidate for race pads. Essex Parts has just produced a basic intro to track/race pads that you may find useful:
https://www.essexparts.com/news-blog...d-owners-guide. Inside are a dozen or so references to brake system heat and the part pads play in managing it. Essex also has a primer on when to replace discs that might help you: https://www.essexparts.com/news-blog...-my-iron-discs. I've changed my rotors out when surface cracks are wide enough to catch a fingernail dragged at a low angle across the face of the rotor. FWIW, most all of my track time has been in other BMWs running slotted rotors. I've never had a rotor crack to its edge before the surface cracks were already wide enough that I chose to replace it. That's been true for both plain and slotted rotors. FWIW, I have seen quite a few drilled rotors at the track that were cracked to their edges. One other thing: how aggressive a pad you choose to run is related to how sticky your tires are. Any person or shop/retailer you might ask for pad advice should ask you what tires you intend to run. The two go together in that the more aggressive the pad, the grippier the tire needs to be. Otherwise, with an aggressive pad and, say, a street tire, you'd spend an inordinate amount of time in the ABS as the pad grips the rotor hard while the tire won't grip the track surface in a like fashion. I hope that makes sense.
CP911986.50 |
03-29-2019, 04:59 PM | #218 |
Rep 326
Drives: 2020 X3M40, 2000 Z3M, 2017 X1
I installed Hawk HP 5.0 pads with new BMW rotors and fluid flush today in my 228 w/o M Perf brakes. After bedding in per Hawk instructions, they seem to work good. The only problem I have now is the rear brakes have a scratching/squeaking sound. The rear brakes have a small drum brake inside the disk for the emergency brakes, and I'm wondering if that is where the problem is. Anybody else have this problem?
03-29-2019, 07:22 PM | #219 | |
Rep 5,577
Then depending but at over 50K mikes you’ll need to adjust the emergency brake if it’s anything like my mercedes. |
03-30-2019, 09:30 AM | #220 |
Rep 326
I just found an article on Bimmerpost that says this noise is caused by the E Brake shoes contacting the shield. www://E90post.com/forums/showthread.php?t=697365
Since the brake shoes do not rotate with the wheel, I'm guessing that the new rotor is touching the shield. This sounds like my problem. I'll see if it goes away by itself and if not, I'll check this. |
