2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Exhaust Actuator Stuck - Can't Reinstall
      05-31-2016, 07:32 PM   #1
crbalch
The Schwab
crbalch's Avatar
Drives: 2020 AW M340xi
2017 BMW X1  [0.00]
2016 BMW M235xi  [0.00]
Hey all,
I just put my stock exhaust back on, and when reinstalling the valve actuator, I could not for the life of me get it to go back on.
When doing some research on the part itself, the picture that ECS Tuning has shows the little mechanism correctly. (the metal slot within the red circle)
However, mine is actually turned 90 degrees, and I am not sure how to get it to go back to install it. I tried letting the exhaust warm up, etc. but it wasnt doing too much.
Any thoughts?
      06-01-2016, 01:12 AM   #2
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
Originally Posted by crbalch View Post
Hey all,
Any thoughts?
can't you just turn it with a screw driver?
      06-01-2016, 06:17 AM   #3
crbalch
The Schwab
crbalch's Avatar
2017 BMW X1  [0.00]
Hey all,
Any thoughts?
Would I risk breaking it? Isn't it mechanical?
Feels very tight...I haven't tried with a screwdriver because I don't want to screw anything up.
      06-01-2016, 10:17 AM   #4
pikcachu
pikcachu's Avatar
1399
not sure... not aware how it works
      06-01-2016, 11:13 AM   #5
mdputnam
mdputnam's Avatar
289
Ok pure speculation on my part, but take a look at the following picture:
There are three wires going into the actuator, purple, brown, and green with a yellow stripe. Typically brown is negative in BMW wiring (-12 volts). While attaching the middle pin to -12 volts I bet if you apply +12 volts to the pin attached to the purple wire the metal slot with the red circle will rotate clockwise, apply +12 volts to the pin with the green wire/yellow stripe and it will rotate counter clockwise. Or vise versa
      06-01-2016, 11:16 AM   #6
crbalch
The Schwab
crbalch's Avatar
2017 BMW X1  [0.00]
Hmm interesting thought...not really sure how to apply voltage though. Will need to investigate more
      06-01-2016, 11:21 AM   #7
mdputnam
mdputnam's Avatar
289
Or just rotate the valve inside the muffler!
      06-01-2016, 11:28 AM   #8
BentZero
BentZero's Avatar
This, except rotate the valve to open and don't install the actuator. The stock exhaust isn't so loud that it ever needs to be muffled even further. Especially since you're coming from an aftermarket exhaust.
Build thread
      06-01-2016, 11:30 AM   #9
crbalch
The Schwab
crbalch's Avatar
2017 BMW X1  [0.00]
I have rotated the valve but it still won't fit for some reason...I don't know what is going on with it.
I had to ziptie the valve open because it was rattling, so thats my temporary fix at the moment.
I'll snap some pictures a little later to show you guys what I mean.
Originally Posted by BentZero View Post
This, except rotate the valve to open and don't install the actuator. The stock isn't so loud that it ever needs to be muffled even further.
      06-01-2016, 11:30 AM   #10
crbalch
The Schwab
crbalch's Avatar
2017 BMW X1  [0.00]
Does anyone have a picture of how the actuator and the valve wire get installed just so I can double check?
      06-01-2016, 11:32 AM   #11
BentZero
BentZero's Avatar
also, you could just plug it up, put the car in sport mode and have it rotate itself to the open position.
Build thread
      06-01-2016, 11:33 AM   #12
crbalch
The Schwab
crbalch's Avatar
2017 BMW X1  [0.00]
Tried that as well...does not seem to do anything cycling through the various modes, letting it warm up, etc.
Maybe the actuator itself is broken...if so, I will go to the dealer.
      06-01-2016, 11:38 AM   #13
BentZero
BentZero's Avatar
Yeah, sounds like it may be. If you can wait I'll send you mine. i don't need it. i disconnected it first day I owned the car lol. Actually, I can disconnect it tonight and send it out tomorrow. PM me your info and it's all yours.
Build thread
      06-01-2016, 12:31 PM   #14
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
You can use a battery from a cordless drill.
Pull it and test it.
      06-01-2016, 01:34 PM   #15
orangeglim
Drives: 2019 M2C
2019 M2C  [0.00]
Sorry for a minor thread jack here, but what does this valve/actuator do on the stock exhaust?
Last edited by orangeglim; 06-01-2016 at 01:37 PM.. Reason: spelling/missing words, derp.
      06-01-2016, 01:35 PM   #16
crbalch
The Schwab
crbalch's Avatar
2017 BMW X1  [0.00]
Originally Posted by orangeglim View Post
Sorry for a minor thread jack here, but what does this valve/actuator on the stock exhaust?
If you're asking what it does, it opens and closes the flap in the left muffler outlet (quieter on cold start, etc)
      06-01-2016, 01:38 PM   #17
orangeglim
Drives: 2019 M2C
2019 M2C  [0.00]
Under what scenarios does it do this? Only when in sport or sport+ mode?
      06-01-2016, 03:18 PM   #18
crbalch
The Schwab
crbalch's Avatar
2017 BMW X1  [0.00]
Just search, tons of results will come up regarding the valve functionality
      06-01-2016, 05:14 PM   #19
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
From what I remember...
It opens when starting the car cold. Then it will close after a minute or two. This is why your car is much louder on startup when the engine is cold then quiets down.
Putting the car in sport of sport+ opens it as well.
Mostly used as a way to regulate the exhaust noise levels.
      06-01-2016, 09:24 PM   #20
BentZero
BentZero's Avatar
Pulled mine. Here's a pic to see that mine looks like. Not sure what position it's in lol. Used a bit of wire to keep the flap open and a tie strap to keep the connection up underneath the car.
Just got back from a late night drive. Love those. No one is out and the temps are perfect. Windows open and I didn't hear any rattles. Wire holding the valve open didn't melt either.
Build thread
