05-26-2016, 05:39 PM | #1 |
SMSgt
22
Rep 87
Drives: 2016 M235i
Power Drop a Week after Dinan Stage 3 Install
So, I picked up my 2016 M235 from the dealer about a week ago after they installed the Dinan Intercooler and Stage 3 flash. It was running extremely well until today. Torque Pro was showing 400hp & 454ft lbs, and just shy of 12psi. Today, I noticed it was significantly slower, especially at lower RPMs. It was only pushing about 10psi and registered a max of 385ft lbs and 375hp.
I'm scheduled to take it in to the dealer next Thursday (because the dealer is far from where I live). I'm thinking boost leak. They didn't pressure check the piping after the intercooler install. The temperature is about 20 degrees warmer, but it shouldn't have THAT much of a performance hit. In my experience tuning turbo'd cars, they run higher boost in hotter temperatures because the air is less dense. Thoughts?
2016 BMW M235i
Mods: Dinan Stage 3, Dinan Intercooler, Dinan Intake, M Performance Exhaust w/CF Tips, M Front Splitter, M Rear Diffusor, M CF Spoiler |
05-26-2016, 05:48 PM | #2 | |
Rep 3,127
05-26-2016, 05:51 PM | #3 |
SMSgt
22
Rep 87
Drives: 2016 M235i
Not according to TorquePro.
05-26-2016, 06:01 PM | #4 |
SMSgt
22
Rep 87
Drives: 2016 M235i
I actually tried calling Dinan Tech support before calling the dealer. No one ever seems to answer the phone over there.
05-26-2016, 06:05 PM | #5 |
Rep 5,102
Cracked charge pipe?
05-26-2016, 06:07 PM | #6 |
SMSgt
22
Rep 87
Drives: 2016 M235i
If that's the case, the dealer would have done it during the install. It's possible I guess.
05-26-2016, 06:27 PM | #7 |
Gettin It Figured Out
1820
Rep 2,669
Diverter Valve....replace with GFB DV+
OEM weak link like the Charge Pipe Edit: shot in the dark .
05-26-2016, 06:30 PM | #8 |
Rep 190,725
Could be a million things, take it to the dealer and let them check it out
From what you are describing sounds like a boost leak
05-26-2016, 06:41 PM | #9 |
SMSgt
22
Rep 87
Drives: 2016 M235i
Bypassed the tune, then switched back to S3. It's also cooler outside. Last run was 100 less ftlbs and about 30 less hp. Boost was at 10.3psi.
I swear I can faintly hear what sounds like pressurized air coming from the front end (not spooling or normal boost/blowoff noises. I know the difference). Guess I'll have to wait until next Thursday to find out. Hopefully, it's a simple leak from a loose clamp. |
05-26-2016, 06:42 PM | #10 |
SMSgt
22
Rep 87
Drives: 2016 M235i
On a side note, Dinan customer service is amazing.
05-26-2016, 09:11 PM | #11 |
Rep 818
Welcome to the world of heat soak.
If you have an OBD reader, check your intake temps. 85 degrees on a hot day may mean nothing, but your intake temp matched with maybe sitting in some traffic... that will give you some pretty high intake temps sufficient enough for some proper heat soak. |
05-27-2016, 06:21 AM | #12 | |
SMSgt
22
Rep 87
Drives: 2016 M235i
05-31-2016, 04:05 PM | #13 |
Rep 424
Plus you got that awesome intercooler
05-31-2016, 04:25 PM | #14 |
Rep 1,931
never had power loss while running stage 3 dinan box.
www.nybmwcca.org
05-31-2016, 05:58 PM | #15 |
SMSgt
22
Rep 87
Drives: 2016 M235i
When I first had it installed, there was a huge surge of torque around 3500rpms. Now the torque is peaking at 5500rpms.
I'm taking it to the dealer on Thursday to have it checked out. |
06-02-2016, 05:35 PM | #16 |
SMSgt
22
Rep 87
Drives: 2016 M235i
Turned out it was a substantial leak in the hose that connects the crankcase to the intake (on the intake end of the hose). Replaced the hose and now it's back to beast-like.
06-02-2016, 05:36 PM | #17 |
SMSgt
22
Rep 87
Drives: 2016 M235i
I'm shocked it didn't throw a code. So we're the technicians.
