2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Drivetrain Malfunction
      05-23-2016, 02:33 PM   #1
BmwBk35i
Question Drivetrain Malfunction
I was driving pretty normal and dash popped up with drivetrain malfu anyone else experienced this (i have jb4)
      05-23-2016, 02:35 PM   #2
Mywifes335
Mywifes335's Avatar
Drives: 2014 FBO M235i
Once. I had meth kick in too early and raised the psi threshold.
That's the only time.
Originally Posted by Axius View Post
Why the sad face, I fucking love sausage.
      05-23-2016, 05:00 PM   #3
Orenji
Orenji's Avatar
26
Drives: 2015 m235i
JB4 has given at least two people I know the drivetrain malfunction due to the fuel pressure not dropping off.
In order to know what went wrong in your situation, you really need to post logs on the BMS forum or send them in to Terry. You should do this as soon as possible.
      05-23-2016, 05:18 PM   #4
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
I've had it happen twice. Both times it was during the first minute of driving after installing my Jb4. Turned car off and back on and haven't had the issue since.
Low fuel pressure will usually cause a CEL and limp mode. Don't think the OP is referring to this.
      05-24-2016, 09:41 PM   #5
wakemcs
Drives: F-Type
I'm having this happen to me now but it shows up on startup. Hasn't happened to me while driving yet.
Fault codes I get are wastegate related:
122108 BOV plausibility -- Ignore, tuner code
123412 electric wastegate, stop learning: stop position (wastegate closed) Not Found
120408 Reduced power mode
123401 Wastegate Learning Stop During *** Heading Cycle
      05-24-2016, 10:43 PM   #6
N55guy
N55guy's Avatar
214
Drives: 2014 m235i
2014 BMW m235i  [0.00]
I've had this twice. Right after uninstalling jb4 for the first time for a dealer visit and then again after reinstalling it. Both happened within the first few feet of driving immediately after uninstall/install. Each time I just turned the car off and turned it on again, no issues after doing that each time. Dealer did not mention any codes.
      05-25-2016, 05:50 AM   #7
BD_F22
BD_e92
Drives: 2015 m235i xDrive
What map are you running? And is your firmware up to date? At one point Map 2 had a bug in it that would trigger a drivetrain malfunction but Terry fixed it with just a firmware update.
      05-25-2016, 08:29 AM   #8
wakemcs
Drives: F-Type
I'm running Map 5 and the F Series OBDII EWG 6 firmware.
Sorry OP, I don't mean to derail your thread. I figure the more information in here the better.
      05-25-2016, 08:50 AM   #9
kd0t
I had the wastegate failure codes on my brother's F30 and my SA said it's a common problem. I forget what the cause was but it was covered under warranty
      05-25-2016, 09:13 AM   #10
wakemcs
Drives: F-Type
Interesting. Did he have a JB4 when he took it in?
I've had the JB4 for a while with no issues but I recently installed the flex fuel and ewg harness as well as the OBDII cable. After the install is when I started to get the fault codes so it makes me think it's a setting on the JB4 that I've either got wrong or needs to be adjusted for my specific situation. I'm also posting on n54tech to try and troubleshoot my JB4 settings, which has revealed some out-of-"default" settings.
      05-25-2016, 11:23 AM   #11
kd0t
My SA doesn't mind mods but I didn't have the EWG wires plugged in. Jon at Burger mentioned that if I had EWG wires plugged in, maybe the DWP (?) was set too high
      05-25-2016, 02:41 PM   #12
wakemcs
Drives: F-Type
Gotcha. I had my DWP setting at 6, which is incorrect. I set it to the default 60. Hopefully that clears up my issues.
      05-25-2016, 04:41 PM   #13
jmwilson125
Drives: 2016 M235i
I just had this happen twice to me. Removed the jb4 and it went away. I am talking with Terry now currently, hopefully it's an easy fix.
      05-25-2016, 06:52 PM   #14
N55guy
N55guy's Avatar
214
Drives: 2014 m235i
I'm just running map 1 but haven't updated firmware... No PC... Looking to get Bluetooth to update and log but wheels sounded better so I bought those and I'll take care of this once my wife forgets I bought the wheels lol
      05-25-2016, 10:10 PM   #15
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
My car does this thing where this happens for whatever reason and then it will persist. The way I have found to get it to go away is to disconnect battery and then unplug one of the EWG wires for a few seconds. Then replug back up and put the battery back. Weird enough that does fix it.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010
The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35
      05-25-2016, 10:11 PM   #16
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
Any chance you could look at old paperwork from the service and see what they fixed?
Follow my builds:
      05-25-2016, 11:25 PM   #17
Anas M235i
Anas M235i's Avatar
Saudi Arabia
14
Drives: Alpine white, Coral red M235i
I have It every time I do a couple WOT back to back between 4th and 6th gear. and I don't know why :'(
2014 M235i AW 8AT,
ER: FMIC & DP & CP ,
BMS: JB4 EWG(OBDII)
      05-25-2016, 11:26 PM   #18
kd0t
Here you go.. But keep in mind my SA does not mind mods at all. So proceed at your own risk! Haha
      05-25-2016, 11:48 PM   #19
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
Mine doesn't either. Thanks!
Follow my builds:
      05-27-2016, 11:32 PM   #20
Taunto
Car Enthusiast
Taunto's Avatar
Drives: 2016 BMW M235 X-drive
:O
From a BMW Dealer Tech stand point... That is one Awful story lol.
      06-06-2016, 07:50 AM   #21
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
After this fix has he seen the issue again? I would have thought the issue was on the jb4 communication to the wastegate side not the actuator itself. Just confirming before I go ask my SA.
Follow my builds:
      01-26-2017, 09:29 PM   #22
Alpine435
Alpine435's Avatar
Drives: 2014 Alpine White 435i M Sport
So after doing some pulls I got a drivetrain Malfunction, and I got these codes, I tried clearing them but they kept popping back up. Has anyone experienced this before? Looking for any help. Im running Full bolt ons E35 mix and have EWG wires and flex fuel wires.
