05-13-2016, 02:14 AM | #1 |
Rep 2,357
Pure Stg 2 Installation
Dear peeps
I am planning on DIY'ing this installation and have spend a good two hours searching for a guide/write-up (even Charles from Pure says they exist), but to no avail... I have all the tools - has anyone got a few dos and donts? I hear lowering the engine will save you some swearing later on???
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
05-16-2016, 10:44 AM | #2 |
Rep 139
Drives: Mineral White BMW M235i, X5
Guess their are no Do's or Dont's
We will learn from your mistakes and hardships. Good luck hope she turns out the best for you. |
05-16-2016, 03:30 PM | #3 | |
Rep 1,422
05-16-2016, 03:40 PM | #4 |
Rep 647
Very much so, i do all my mods... I can afford more by doing it that way plus i only have myself to blame if something goes wrong. I have also thought about a pure stg 2 and would do it myself as well... Good luck and look forward to your posts
05-16-2016, 03:54 PM | #5 |
Dream crusher
984
Rep 2,421
Are you getting the installation kit from pure?
Don't reuse the stock DV if you're planning on going over 100hp from stock.
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
05-16-2016, 03:55 PM | #6 |
Rep 1,422
Good to know... Why? Does it leak or break?
05-16-2016, 04:02 PM | #7 |
Rep 893
It's prone to leaking. Upgrade to the GFB DV+, you can purchase it from Pure. I would also recommend the high flow inlet!
2019 SG M5C
05-19-2016, 01:37 PM | #9 |
3441
Rep 79,212
05-19-2016, 02:22 PM | #10 | |
Rep 1,422
I'm thinking: - turbo - install kit - DV I already run meth and JB4, so PI and LPFP isn't necessary, right? |
05-19-2016, 02:40 PM | #11 |
Rep 887
Drives: Enzo F23 228i
does this happen to the N20 also? Also, is this a pain to change?
06-01-2016, 11:08 AM | #12 |
Rep 2,384
Would the DV cause a strange vibrating type rattle if it was leaking?
I get a strange vibrating rattle at idle on my car...not sure if its the wastegate rattle (but doesn't sound like my old n54 rattle used to, its more of a vibrating rubberry noise), or maybe its the exhaust valve? |
06-01-2016, 11:16 AM | #13 | ||
Rep 893
Don't think you can exceed 23psi on just meth, I'm currently on pi with stock lpfp and am pushing 23-24psi on e65. Will upgrade the lpfp soon for straight e85 at 27psi.
2019 SG M5C
