05-20-2016, 04:48 PM | #23 | |
Rep 190,805
Let me explain. AA8, Enzo, Jb4 and Jb can all give you the same power on stock turbos. It just comes down to what each company feels is a safe amount of boost to target on a stock car Burger Tuning feel that it is not safe to target more than 3.5 psi on the N55 if the user does not have the ability to log the car and make sure all is safe. Thats why 3.5 psi is the max stage 1 can offer the JB4 map 1 (same manufacturer) gives you +4 psi on the same engine because Jb4 can datalog and user will be able to monitor different variables to make sure all is running smooth. They also offer auto tuning map 5 which can target higher boost if the JB4 feel it is safe. And you have Map 6 which lets the user custom tune the car and target any boost they want. Active which is similar to a stage 1 with no datalogging features gives the user the choice of any boost between +3 and +5 psi but they strongly recommend not going over +4 on pump gas and stock car So as you can see it is not that 1 tune can make more power than the other, the reality is different companies have different ideas on what is the safe limit. As for the Dyno, a word of advice.: Never compare advertised dyno figures. Check out AFE inflated dyno numbers and you will know why. To compare power either check dragtimes.com or get the same car on the same Dyno within a very reasonable period of time If you ask all three tuners for a race map, all three maps will give you very similar results
05-20-2016, 05:29 PM | #24 |
Rep 58
Mike,
Thank you for the info and that is pretty much inline with what I have seen discussed here on the forums in all the previous threads about the different piggy back modules. But, not sure you really addressed my question specifically in your listing of what those modules all do and how much across the board power/boost they add because you didn't go into the same detail regarding the Enzo Performance product which of course is a flash tune, not a piggy-back module. My own research over the past few months echoes what you said about some modules offering one level of boost or another but again, isn't a flash tune a different beast altogether? You said earlier that any of those Stage 1 tuners was comparable in the power added by a dedicated Enzo flash tune. Do you mean to say that the flash tune that Enzo is doing for 1400 bucks (and again I am talking just on a unmoded M235) is essentially the same as what I can get with the JB4 or Active 8? Again, I am not trying to put you on the spot, I would genuinely prefer to spend 500 bucks for a module as opposed to 1400 for a flash tune but I still am not seeing how the two are comparable as you said they were for a unmoded car. What I want is smoother power delivery and more power and torque without slapping a ton of stage 2 style mods on my car. It sounded like the Enzo tune, while the most expensive, seemed to give the best results. I've done ECU flashes before and have always been happy with the results on various vehicles, and I have also used tuner modules (mostly on my motorcycles) but if a piggyback module will give me comparable results on my forthcoming M235, I will gladly save the money and buy a JB4. Madmatt
2016 F22 M235i Black/Black * ZF8 AT * ZTP * ZDA * ZCW * H/K * JB+
2015 F15 X5 50i Mineral White Metallic/Mocha Last edited by Madmatt; 05-20-2016 at 10:49 PM.. |
06-07-2017, 12:53 PM | #25 | |
Rep 190
Mike, any input on what mods (in tandem with a JB4) would more safely allow > or = +3.5 psi on pump gas? Or should I assume the Combo deals essentially cover that? |
06-07-2017, 03:09 PM | #26 | |
Rep 1,184
From there add some ethanol and meth if you deire more power roughly ($400) All of that should put you in the ballpark of 400-420 whp and 450+ wtq I think. That's where I am now. Did all of the installs myself too, they are fairly simple if you know your way around the car. Picking up pure's inlet pipe soon. |
MadOzodi53.00 |
06-07-2017, 03:15 PM | #27 | |
Rep 1,184
MadOzodi53.00 |
06-07-2017, 03:24 PM | #28 |
Rep 1,931
hate to tell you guys, but i highly doubt you'll be over 400whp with any tune with just bolt ons, and you can forgot about 420 -450 without meth.
Jb4 + catless dp+ charge pipe + intake + fmic + e85 is about 375whp. Flash tune + catless dp+ charge pipe + intake + fmic + e85 is 395whp. Flash + jb4 (or jb+) + catless dp+ charge pipe + intake + fmic + e85 is 400- 405whp. An enzo tune or any flash for that matter will get you more tq and a few more whp than a jb4 or any piggyback. Its safer for the car and wont throw any drivetrain codes. There are cheaper flash tunes available which are very conservative. I'd stay away from them for multiple reasons. Hit up enzo on his facebook page, tell him i sent you, ask for my map. https://www.facebook.com/tunedbyenzo/
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic Last edited by bryan_G01; 06-07-2017 at 03:33 PM.. |
MadOzodi53.00 |
06-07-2017, 03:26 PM | #29 | |
Rep 1,931
Run a little e85, youll be a little faster than a m240.
www.nybmwcca.org
MadOzodi53.00 |
06-08-2017, 07:55 AM | #30 | |
Rep 190
As always, "you gotta pay to play"...the JB4 may be the route I settle on for now as that seems to allow additional mods in the future. |
06-08-2017, 09:04 AM | #31 | |
Rep 1,931
Purchase something you can use later on with whatever route you go. Jb4 is good, can be used with a flash if you want to stack later on.
www.nybmwcca.org
06-08-2017, 09:38 AM | #32 |
Rep 190
Yanno, it'd be nice if COBB put out an Accessport for the N55. I don't know the full story behind their N54 stuff, but I assume they didn't make enough $$$ to justify N55 development.
06-08-2017, 06:34 PM | #34 | |
Rep 1,931
And Cobb sucked horribly for n54 cars...
www.nybmwcca.org
MadOzodi53.00 |
06-09-2017, 08:31 AM | #35 |
Rep 190
Unfortunately, COBB is my only experience with flash tuning, so I've got some reading-up to do.
OR...save the modicum of brain cells I have left and be happy with piggyback. E85 isn't available in acceptable proximity to where I live. Thanks for being patient and courteous with the replies! |
06-09-2017, 11:52 AM | #36 | |
Rep 1,184
