05-06-2016, 02:16 PM | #1 |
Rep 103
Downpipe only
Is anyone here running only a downpipe? I'm interested only in getting an awesome exhaust sound, and not so much for performance. Not really interested in a tune and then having to get an aftermarket chargepipe either.
I recall an old post awhile ago of someone else that only got a downpipe for some better throttle response, but I cannot find it via search... Will there be any problems with air fuel mixture, etc, running only a downpipe? Would I have to get an aftermarket chargepipe anyways just in case? Thanks all |
05-06-2016, 03:04 PM | #2 |
Rep 1,503
You can run the downpipe only without a tune, you will just get a CEL on the dash. I think it might prevent you from going into sport or sport+ mode.
If you don't want to tune then I'd suggest getting the CANBus Module by BMS, that will clear the CEL from the DP among other features.
FBO M235i r
F80 M3 |
05-06-2016, 04:23 PM | #3 |
Rep 190,777
You can run downpipes on a stock car without any problems, only problem will be the the CEL light
Downpipe on its own will get you a better sound and a small bump in performance If you run JB4 with map 1 with the downpipes, you will not need a CP and it will take care of the CEL for you
05-06-2016, 08:34 PM | #4 | |
Rep 1,117
Drives: 2015 BMW M235i
05-06-2016, 08:50 PM | #5 |
Rep 1,503
Any sort of light indicating a malfunction locks you in comfort from what I've seen. Even when I had a low tire pressure light in the winter, I couldn't go into sport mode.
FBO M235i r
F80 M3 |
05-06-2016, 08:55 PM | #6 |
Rep 1,117
thanks for the heads up. I was considering this path also...I guess tune is pretty much required if u go downpipe...
05-06-2016, 09:20 PM | #7 | |
Rep 1,503
http://www.burgertuning.com/f_series...odule_BMW.html
FBO M235i r
F80 M3 |
05-06-2016, 09:43 PM | #8 | ||
Rep 1,117
05-06-2016, 09:48 PM | #9 | |
Rep 1,503
The module I linked you stays in the OBD port and will auto clear the CEL from the downpipe. You don't do it manually.
FBO M235i r
F80 M3 |
05-06-2016, 10:25 PM | #10 | ||
Rep 1,117
05-06-2016, 10:45 PM | #11 |
Rep 103
before I go bother BMS, can anyone here verify that the jb4 or canflap module only autoclears certain tuner codes like the downpipe CEL, and not other CEL's that could be serious?
http://www.1addicts.com/forums/showp...2&postcount=20 |
05-07-2016, 07:16 AM | #12 |
Rep 1,931
wagner catted down pipe threw no codes so far.
Sounds is just a little above stock, but pair that with a muffler delete and it sounds very angry.
www.nybmwcca.org
05-07-2016, 09:07 AM | #13 |
Rep 242
Running the Fabspeed catted downpipe (F30) and no CEL since installed 6 months ago. I'd say it sounds quite a bit more aggressive than stock, especially on cold starts.
05-07-2016, 12:33 PM | #14 |
Rep 190,777
Nice, post a sound clip
05-07-2016, 01:37 PM | #15 | |
Rep 1,422
Ocn55 is correct. |
05-08-2016, 03:54 PM | #16 |
Rep 1,753
If all you're going for is a bit more exhaust note why not just put the money into the BMW performance exhaust? You're pretty close to the cost when compared to a DP and canbus module.
05-09-2016, 12:43 AM | #17 |
Rep 103
05-09-2016, 01:15 AM | #18 |
Rep 1,503
Try a resonator delete. Super cheap and makes a slight difference. It may satisfy the craving for more sound, for now...
FBO M235i r
F80 M3 |
05-09-2016, 07:17 AM | #19 |
Rep 1,753
:| You said downpipe only......lol. Well then yeah, either get a louder exhaust or DP or resonator delete. All will help.
05-12-2016, 12:16 PM | #20 |
1006
Rep 1,653
Our Sport Cat Downpipe is definitely something to check out! I ran it on my M235i as my only mod for awhile before betting the Muffler Bypass Exhaust. It was a great bump in performance and sound! The best part about it was no CEL! Check it out on our website here.
John S | Performance Specialist
john@Fabspeed.com P: 267-742-3045 | F: 215-646-9828 155 Commerce Drive | Fort Washington, PA 19034 | USA www.fabspeed.com |
05-12-2016, 03:56 PM | #21 | |
Rep 190,777
05-23-2016, 09:34 AM | #22 |
The Schwab
473
Rep 1,605
Drives: 2020 AW M340xi
Just ordered my sport cat downpipe from Fabspeed Motorsport , can't wait to get it in!
