01-13-2020, 02:05 PM | #45 | |
Bimmer Nut + Software Dev
553
Rep 802
Drives: 2018 Audi S3 IE Stage 1
Thanks!! I got a good laugh too, haha.
Current: 2018 Audi S3 IE Stage 1
Past: '08 Infiniti G37S, '87 Porsche 944 Turbo, '13 328i, '15 M235i, '15 F80 M3, '16 M235i, '15 335i, '17 X5 xDrive35i @whoismorggan |
01-15-2020, 07:45 PM | #46 |
553
Rep 802
Replaced all six ignition coils today with Bavarian Autosport's High-Performance Ignition Coils.
I was experiencing some misfiring and breakup when giving the car some juice while cruising. After putting in the new coils it's as smooth as butter! Will report back if I experience any MPG gain or noticeable performance improvement. Purchased from ECS Tuning: https://www.ecstuning.com/b-bavarian...coil/5005~bav/ Car currently at 83,000 miles
Dylan861330.00 |
01-16-2020, 07:05 PM | #47 |
553
Rep 802
EDIT: it's not as smooth as butter. Still experiencing misfire
On to the next culprit.. injectors? Also clocked a new PR 0-60 of 3.79
Vervain397.50 |
01-30-2020, 09:59 AM | #48 |
553
Rep 802
Recently had Tint World tear off the tint and clean up all windows. Tired of looking for an inspection shop that will pass me with 20% tint. Back to the fishbowl look
3.75 0-60 last night
Vervain397.50 |
01-30-2020, 02:32 PM | #49 |
553
Rep 802
Today I decided to try out xDelete and my stuttering/"misfire" issues have disappeared. MechEngineer notified me that my issues sounded like his and it was the transfer case causing problems.
It feels night/day better! Accelerating from a standstill is a lot smoother, accelerating while in 3rd-5th gear is amazing -- no stuttering or choppiness, and the car feels nimbler in the frontend. Not to mention I can now swing the back end out on turns and light up the tires a bit Best $150 I've spent on the car so far!
01-30-2020, 03:23 PM | #50 |
Rep 561
01-30-2020, 05:10 PM | #51 |
553
Rep 802
It's called Dragy and pairs with a GPS module via Bluetooth
01-30-2020, 05:50 PM | #52 |
553
Rep 802
Installed the AutoTecknic Carbon Fiber & Alcantara E-Brake Handle today. Looks and feels great. Waiting for a carbon shifter surround to replace the silver one and then I'll finish it off with the center steering wheel trim.
Straightforward install. Took maybe 10 minutes.
01-31-2020, 04:59 PM | #53 |
553
Rep 802
T-Carbon shifter surround trim came in. Looks awesome 😎
01-31-2020, 09:19 PM | #54 | |
Rep 43
01-31-2020, 09:47 PM | #55 | ||
553
Rep 802
Thanks!! It's been a fun process. The torque limit was increased by the MHD tune I believe
01-31-2020, 09:57 PM | #56 |
Rep 43
Makes sense. Mine is total stock for now except the previous owner put 255s on the rear. Had my car for a month and I think I'm going to want to replace the seats with the M4 equivalent. I'm afraid my fat ass just doesn't fit in the 235 seat very well...
02-05-2020, 03:48 PM | #57 |
553
Rep 802
Got some new wheels fitted today! Picked them up on Tirerack.com
TRMotorsports C4 in grey - 18x8 +40 square. Still running 225/40 tires right now, but will probably try to go a little bigger in the rear. I'm in love
123Britt289.00 |
02-07-2020, 10:38 AM | #58 |
553
Rep 802
Made some dyno pulls today at Stage Fab & Performance. Results are 347 WHP & 396 ft-lbs torque. Running MHD OTS Stage 2 - 93 OCT.
VRSF intercooler and custom pro-tune are on the list next
02-08-2020, 07:59 AM | #59 |
Rep 2,214
Nice power, right where it should be on stock FMIC and OTS. Curious how you make out with FMIC and custom tune, as I prepare to finally flash mine this year..
whoismorggan553.00 |
02-12-2020, 11:00 AM | #60 | |
Rep 439
Drives: 2016 M235i Xdrive 8A
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete |
02-12-2020, 11:08 AM | #61 |
553
Rep 802
Thanks! I love the look. I wish the OEM M-Performance alcantara/carbon trim wasn't $800+ ... I decided to emulate the same look for around $200
02-12-2020, 03:36 PM | #62 |
Rep 439
How did you pull that one off? I was about to order the $800 kit.
02-12-2020, 04:24 PM | #63 |
553
Rep 802
I wrapped all of the trim myself in a suede/alcantara-style vinyl that I purchased on Amazon. Then ordered the Autotechnic carbon & alcantara ebrake handle, and a gloss carbon shifter trim from eBay.
02-12-2020, 04:46 PM | #64 | |
Rep 439
So you are down to 3.75s -0-60 with FBO and Stage 1 basically? and the Coilpack (no idea what that is)?
02-13-2020, 12:31 PM | #65 |
Rep 5,372
With that setup, you should be able to run 245/35s at all four corners with no clearance issues. I'm running a square 18X8 et43 setup with 245/35R18 PS4S tires. No clearance or rubbing. No even close. You'll be shocked at the difference in front end grip plus the MUCH meatier look. They are much wider than the 225s.
02-13-2020, 12:48 PM | #66 |
Rep 3,497
Tire Rack shows the following specs for the two tires:
