05-27-2019, 02:32 PM | #67 |
Rep 1,361
Haven't put them on yet. Soon though!
05-27-2019, 10:09 PM | #71 | |
Rep 485
I just swapped out the pads and not replace the rotors for now. *sigh*
2015 M235i xDrive 8AT
05-27-2019, 11:04 PM | #72 |
Rep 485
Lesson learned: changing rotors should be a pretty plain procedure but if something breaks in between, it will lengthen the procedures by 2X-3X, if you are lucky.
05-28-2019, 02:41 AM | #73 | |
Rep 38
After only 15k miles on them my tires are "cupped" on my M240 XDrive. You could also try Stone's German Garage - they're good and fairly priced. Saved me a lot on my old 330i. They could help with your brakes. |
05-28-2019, 10:41 AM | #74 |
Rep 448
Just put red stuff pads on my front wheels over the weekend. The install was even easier than changing the pads on my 135. Will install red stuff on the rears perhaps next weekend, but wanted to make sure the fronts were working properly.
So far, so good but still need to get the pads bedded in. |
05-28-2019, 11:36 AM | #75 | |
Rep 2,214
Be sure to use some anti-seize paste on them next time!
05-28-2019, 11:57 AM | #76 |
Rep 2,882
I'm gonna suggest you stop here and find that decent indie mechanic you should have started with in the first place. Sounds like you have brakes that are more than a bit corroded and frozen (having lived in MN for a year, I'm not surprised). Pad swap, even w/ rotors, is pretty simple IF everything goes smoothly, but it isn't. Much of what you'll be paying for is the experience and know how - I'd want s/b to really verify that all the pistons move freely, no torn boots, bent hardware, or sticking pads. Also to verify that rotors really sit flat and true (runout will cause irregular wear and vibration, eventually pulsing). You'll also want s/b with an ISTAR (or whatever they call the tech computer) so you can flush the ABS - whatever fluid is still in there is probably pretty far gone. You may find that the indie place will let you watch and learn - this is what I did, so eventually I'll go the DIY route. Once you find a place, ask them about their policy for aftermarket parts, as everybody is different.
05-28-2019, 08:04 PM | #77 | |
Rep 745
Anyways, take a torx bit, hammer it in and use that to back it out. I forget the size; might have been a T8 that worked well for me. Now I know why the directions call for replacing that screw. The damn things probably strip every time you try to remove them!
05-28-2019, 09:19 PM | #78 | |
Rep 485
05-28-2019, 09:20 PM | #79 |
Rep 485
Yup, I agree. I think I will have to hammer it out after I thin it down using a drill.
05-28-2019, 09:21 PM | #80 | |
Rep 485
05-28-2019, 09:25 PM | #81 | |
Rep 485
I did use a brass brush to clean the crevices before I replaced the pads. The replacement of pads were recommended by dealer because they were close to min thickness. I'm planning to get the car to an indie mechanic to get the brakes flushed after I'm done with replacing the front rotors.
Unicorn123186.50 |
05-31-2019, 12:48 PM | #82 | ||
Rep 87
If you are in California (which you're not), state law requires that they give you the old brake pads - you can then inspect them and see if 4mm really meant 4mm, or it was 5mm, 6mm, or "time to sell some more brakes". In my case, I was told it was at 4mm and I had to replace them but it was really closer to 6mm after measuring. Driven over 6K miles after being told I had to replace them, and still no light on. Now that I think about it, the story about having to send in brake pads to BMW and them checking for wear within spec for maintenance plans is BS, because California state law requires consumers be able to request the old parts Last edited by EstorilM240; 05-31-2019 at 02:12 PM.. |
05-31-2019, 07:29 PM | #83 | |
Rep 255
Current Fleet, 16 F22 M235i xDrive, 15 Audi Q5 3.0 TDI (my Wife's), 07 E85 Z4M Roadster, 01 Toyota Tundra 2wd Long Bed
Retired (a few of them...), 08 E60 550i 6M, 01 Audi S4, 70 Fiat 124, 88 E28 M5, 72 Datsun 510 2Dr, 73 TR6 |
06-01-2019, 03:41 PM | #84 | |
Rep 485
06-01-2019, 03:43 PM | #85 | |
Rep 485
Same deal with reloading my own ammo. It was freedom when I learned how to reload effectively.
06-01-2019, 03:50 PM | #86 |
Rep 485
UPDATE: rotors retaining screw
06-01-2019, 06:29 PM | #87 |
Rep 3,506
I believe the OEM rotor sizes for the blue M-Sport brakes are: Front – 340x30, and Rear – 345x24.
06-01-2019, 06:31 PM | #88 |
Rep 485
You are correct. I learned this the hard way.
