2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Engine Squeal / Squeak under partial throttle
      09-05-2021, 04:04 PM   #1
Kinesthesia
Kinesthesia's Avatar
Drives: 2014 M235i
This morning I installed both charge pipes and a new intercooler.
Now my car has a strange squeak / squeal at moderate speeds and under moderate throttle. Around 2500 - 3500 rpm's, generally in 2nd or 3rd gear (but sometimes 1st), there is an annoying squeal.
It is not the chassis, suspension, etc. It is 100% coming from the drivetrain.
I do not believe it is a "boost leak" it only happens in the conditions mentioned above and clears up instantly under hard throttle / boost.
It also cannot be replicated with the car sitting still, so I suppose you could say it only happens under load.
I plan to record the sound and add to this thread. In the meantime, any thoughts?
Thanks in advance.
      09-06-2021, 01:27 AM   #2
Awn
Newbie
Awn's Avatar
Saudi Arabia
Drives: BMW M235i
i am facing similar squeal or i would say birds chirping noise that i posted about in this forum but no luck yet. The conditions where it appears almost exactly the same as yours, no replication when car is still, happens at lower rpms and disappears at hard throttling.
here are a couple of videos where you can hear it but better heard with headphones.
let me know if it is the same..
Estoril Blue - Coral Red
      09-07-2021, 09:10 AM   #3
Kinesthesia
Drives: 2014 M235i
I'm pretty sure mine is a boost leak, any tips on how to find it?
      09-13-2021, 07:16 AM   #4
Kinesthesia
Drives: 2014 M235i
I reinstalled intercooler and charge pipes. I found one of the cold side clamps was loose and one of the bungs was crossthreaded.
I took my time and triple checked every connection, as well as threadlocker on the bungs.
Problem solved.
Awn9.00
      09-14-2021, 02:38 AM   #5
Awn
Newbie
Awn's Avatar
Saudi Arabia
Drives: BMW M235i
i am glad you have it fixed, meanwhile i am still searching for answers for my birds chirping squeak
