07-04-2014, 01:33 PM | #23 | |
Rep 160
I'd like little louder exhaust until my M Perf one arrives.
Certified High Performance Driving Instructor - BMW of North America, Porsche Club of America / Chief In-Vehicle Instructor - Fleet Safety International
Gone but not forgotten: 2008 E92 M3; Eisenmann Race Exhaust / Dinan 3.62 Limited Slip Differential / Dinan Software / Dinan High-Flow Intake / Dinan Camber Plates / Dinan Lowering Springs / Dinan Sway-Bars |
07-04-2014, 02:43 PM | #24 |
Rep 602
Yes you can just unplug. Wrapping it with electrical tape would be advisable. But do it after a start up and the left side valve is open. Otherwise you unplug with valve closed.
You will get a better sound change but nothing deeply appreciable. The first 30 seconds of start is great with stock and MPE. An aux air pump has performed its task of keeping valve closed to warm manifold quicker up front & burn those terrible, CAFE extra gases on start up. Arrrgh! Once the 30 secs. are finished, then valve opens and exhaust tones down a LOT. BTW-- The MPE does get better as it gets broken in, [1000Mi.+] but it is not a deep loud sound by any means after those 30 seconds are finished up front. Trying to get ride of the pump is not on my agenda--no need for codes being thrown, or too rich a mixture. Hope this helps some. |
07-04-2014, 03:01 PM | #25 | |
Rep 160
07-04-2014, 04:27 PM | #27 |
Rep 602
Above is correct...it is less when valve is open after those 30 seconds. That's when it really quiets down.
I did not try unplugging with valve closed, ie. before system was started. That option would just mean you have the left sided valve always closed, and right pipe open. But no code is thrown unplugging it and taping up out of way--after it opens up. Just know its not much different, until muffler gets "broke" in a bit. It takes a while and some heat cycles. BUT the valve is just now always open, and you will still get a heartier sound on start up--and yes, it will still quiet down after the pump has done its work, even unplugged. Try it and if you don't like it, then just plugg'er back in. No real effort...no loss really. It did get a little deeper after a 1000 miles or so. Last edited by zkeeper; 07-04-2014 at 04:35 PM.. |
