2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Open Trunk without Fob
      01-25-2018, 04:10 PM   #1
bacampbe
Drives: 2024 Z4 M40i PB
Hi,
My wife's 328 lets you open the trunk from the outside without the fob if the car is unlocked. Neither my old m235 and my 2018 m240 seem to allow this (although I could have sworn a loaner m240 we recently got did.)
Is there a setting for this somewhere I am failing to find?
      01-25-2018, 04:25 PM   #2
overcoil
Drives: M235i 6spd
first make sure the trunk lock-out switch in the passenger side glove box is switched to un-lock -not sure if that even effects your issue, but worth checking first,
      01-25-2018, 05:47 PM   #3
bacampbe
It's in the unlock position. If I put it in the lock position, it locks out the fob entirely.
      01-25-2018, 06:05 PM   #4
overcoil
Drives: M235i 6spd
Have you gone to iDrive to SETTINGS then to DOORS & TRUNK or DOORS & WINDOWS - whatever it says and tried the two settings
      01-25-2018, 06:48 PM   #5
Maynard
Drives: 228iX & M2C
Mine needs 2 clicks of the 'unlock' on the fob and then the handle opens trunk, otherwise it is locked. I think that after I open it from the cabin switch, it is also unlocked for the handle.
      01-25-2018, 06:49 PM   #6
Ron Jeffries
388
Drives: 2018 M240i xDrive convertible
Mine will open from handle whether or not the doors are locked.
      01-25-2018, 08:00 PM   #7
bacampbe
Bingo!
It's under Vehicle Settings/Doors and Key/tailgate. If you set it to "Tailgate and Doors", then anytime the car is unlocked you can open the trunk with no fob. I had assumed that it just meant that if I unlocked the trunk with the fob button, it would also unlock the doors. But it appears to do both.
      02-16-2018, 05:55 PM   #8
kindofblue
Gone electric
65
Drives: i4 40eDrive 3/31/23 & Mach e
Originally Posted by bacampbe View Post
Bingo!
That works but only when the passenger door is unlocked as well as the driver's door. Any thoughts about how to fix this aspect of it? Thanks.
Warmest regards,
Reid K. Hester, Ph.D.
      02-16-2018, 07:15 PM   #9
Ron Jeffries
388
My M240i opens from the handle even with car locked. There's a rubbery bit right in the middle that one presses.
I'm still thinking about finding a way to turn off the fob opening it since I seem to trigger it accidentally more often than on purpose.
      02-17-2018, 01:03 PM   #10
mleskovar
Drives: '18 230i
That's also under "Vehicle Settings/Doors and Key/tailgate" I believe. You can set it to unlock both doors or just the driver door.
      02-17-2018, 07:55 PM   #11
bacampbe
When you say it opens from the handle with the doors locked, do you mean with the fob present? If so, that's normal operation. If it did that without the fob present, I would be concerned.
      02-18-2018, 05:39 AM   #12
Ron Jeffries
388
Yes of course, with the fob in my pocket.
