06-22-2015, 04:43 PM | #23 | |
Rep 5,262
06-22-2015, 09:43 PM | #24 |
Rep 554
Both wonderful but very different. The Carrera is roomier, more insulated from the engine and drivetrain noise and is quite luxurious to drive. But push a few buttons and the personality changes completely. It turns into a real hooligan.
The Cayman has a tighter, some say slightly claustrophobic, interior. The engine is at your back and the transmission under your elbow. You really wear the Cayman. But it all works very, very well. On the track the Cayman is the naturally better balanced car which is quite easy to drive quickly and is very predictable, except when it's not. You see, when a mid engined car spins, it does so VERY quickly. But its a wonderful driver. While not as powerful as the Carrera you use your momentum through corners to really keep your speed up. I absolutely loved the Cayman on the track. The extra power of the Carrera is immediately evident and that's what sold me. It's a completely different feel. The rear weight bias isn't really all that noticeable due to the advances of the new 991 chassis, but the ability to power out of corners so much earlier than the Cayman (and most other cars) is what makes it a joy to push hard. There are no losers here!
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S |
06-22-2015, 11:09 PM | #25 | |
Rep 5,262
Now I see why all the guys that are serious about track days get a GT3 |
06-23-2015, 04:42 PM | #26 | |
Rep 957
I had a 13 991, which saw about 7k in track miles before it was retired due to a tire failure and a retaining wall. My m235i, while not really stock anymore is way more fun. The 991, while fast did not require much input and would always be happy to intrude with its ptv and pdcc. I was at my home track last week, and was running 2 seconds faster in my m235i, than I was in my buddies 991 s with a powerkit. I set both laps and my car is manual and his is PDK. The m235i modded is such an unassuming car, it really catches other drivers off guard. Granted once you mod it as much as I have, you really have to drive it because the power is way over what the traction control systems were designed for, which is so much fun. |
07-01-2015, 09:09 AM | #27 | |
Rep 3,856
07-02-2015, 12:21 AM | #28 |
Rep 67
I raced go-karts/shifter karts for 10 years and late model stock cars for a year... I'm picking up my M235i September 19th in Munich, and will be taking it the the Nurbergring before I come home. Many track days to come after that once it arrives in SoCal.
07-07-2015, 11:14 AM | #29 |
Rep 957
more or less, it is almost like a simulator. It can make a bad driver a pretty good one, because it fixes so much. Problem is take them out of that car and they will be in trouble. I actually redid the rear alignment to give it way more oversteer for fun and to improve my driving. Cayman and 991 are great hdpe cars for 3-4 times a year, but I did not find it very stimulating. Did about 12 track days in it before it was retired.
04-27-2016, 05:55 AM | #30 |
Rep 80
Took my 2er for the first few laps on the 'Ring last weekend. After reading a lot in the forum about you guys tracking your cars I just couldn´t wait finally trying the 2 myself.
I was used to the track to a certain extend, but only from my last car - E92. This felt much more secure, much more steady especially through low speed corners. The 235 on the other hand feels much more agile but also quite nervous on the brakes and on downshifts. I think that will take some getting used to from my side. Lap 1 was quite a struggle to keep things together. Lap 4 was then a smoother. You have to work the throttle precisely through corners and not overwhelm the tires with braking, downshifting and steering on the turn-in too much. I think once you can handle that, the 235 is a very rewarding car to drive on a track. BTW: 4 Laps of the Nordschleife eat roughly half your tank. Picture: |
05-01-2016, 05:03 PM | #31 | |
Rep 356
I'm amazingly jealous too 😃 |
05-01-2016, 07:03 PM | #32 |
Rep 1,931
Can i borrow ur 2er and a couch?
www.nybmwcca.org
05-02-2016, 02:02 AM | #33 |
Rep 80
05-02-2016, 07:20 PM | #35 | |
Rep 18
I auto-x, so I know nothing about brakes, but your tires and brakes may need a rest around the same time...possibly...just a guess...good luck, and please report. |
05-02-2016, 07:24 PM | #36 | |
Rep 818
I've done a number of auto-x's with my previous 330i that was perfectly balanced/neutral so I'm not entirely a noob; but this 235 is clearly a lot more tail-happy, especially with the MP-LSD |
05-02-2016, 08:19 PM | #37 |
Rep 37
Drives: 2016 M235i Coupe
I'm experiencing gas shock just driving it on the highway. I've filled it up from 4 times this week from 1/4 tank! In fairness, I've adding about 800 miles to the car this week due to various circumstances, and I've been showing off many times to my friends on wide, empty roads
I'm going to my first AutoX event this Sunday, getting an oil change/checkup tomorrow to make sure it's nice and ready.
BMW CCA Member# {512318}
05-03-2016, 08:29 AM | #38 | |
Rep 80
05-03-2016, 08:41 AM | #39 |
Rep 554
I don't autocross but I track a lot with MPSS. You want a HOT reading of no more than 38/40. Beyond that you get too much slipping. You can confirm air pressures by using a pyrometer immediately after coming off the track. Take three readings across the tire. They should be very close in temperature. If the center reading is higher you are overinflated. If the outside temps are higher you are under inflated. If you have excess camber the inside temps will be proportionately higher and that is acceptable.
Keep in mind that driving style, car set up and type of track will all affect the pressures required to get to the optimum tire "hot grip" of 38/40. |
05-03-2016, 12:16 PM | #40 |
Rep 1,931
I run hpde with NASANE and BMWCCA.
A few others like hookedondriving and Patroon. Been out 4 times this year already.
www.nybmwcca.org
05-03-2016, 09:43 PM | #41 | ||
Rep 818
05-04-2016, 12:47 AM | #42 |
Rep 80
Okay. I´ll try If it grips just as nicely and helps reducing the outside wear then it´s fine.
05-06-2016, 02:28 AM | #44 |
Rep 80
How did you place the microphone there? I suppose it was an external mic? Sounds phenomenal And also how do you get that //M symbol on the screen?
But why do you change the position of your hands so often on the steering wheel? I had learned that 9 and 3 positions should be kept as much as possible and that you should only let go of the wheel if you need to (hairpin etc). |
