06-24-2016, 09:30 PM | #89 | ||
Rep 845
Hopefully it's just a bad box. It happens.
06-25-2016, 07:50 PM | #90 |
Rep 1,117
Drives: 2015 BMW M235i
Sorry to hear about these issues for you fellas. I'm sure corporate will do the right thing and correct the problems. I actually ran into similar issues twice on my old IS250 manual. It wasn't until it went in for a third time that they replaced the dual mass flywheel and all was good. If they are replacing all the parts under warranty i would strongly push them to mate a new flywheel to the new clutch. These flywheels from my understanding are quite complex, crazy expensive and usually the weakest link unfortunately. I would even say that the gearbox/tranny will still be ok.
My second transmission was grinding after a few hundred kilometres then they finally dumped my original DMF and all was good. Keep us posted! |
06-27-2016, 03:19 PM | #91 |
Rep 845
Update:
Called the dealership and the shop notes said "complete transmission failure" (not entirely accurate, but whatever). My new gearbox is on its way (thank god for warranty). I have a question into the shop foreman as to whether this means flywheel, clutch, gearbox, etc., or just the gearbox. I'll let you know when I find out more.
06-27-2016, 07:25 PM | #92 |
Rep 199
Drives: M235i alpine white on black
Same here, my new transmission goes in tomorrow.
06-27-2016, 09:10 PM | #93 |
Rep 1,117
Did you notice anything abnormal aside from the 1-2 grind at high rpm? When my flywheel was on its way out it was big time inconsistent with engagement, I was getting vibrations in the pedal and under hard acceleration and also some strange noises when first lifting from 1st.
I would think the flywheel is toast in your case as the gearbox is the first victim once they start failing. |
06-27-2016, 09:20 PM | #94 | |
Rep 845
06-29-2016, 03:13 PM | #95 |
Rep 845
Update:
Gearbox is going in the car today. They are only replacing the box -- no flywheel, no clutch. Honestly, I am okay with this. I never had issues with clutch engagement/disengagement or with the flywheel. The problem was isolated to 1-2 shifts above 5000 rpm. Ive done plenty of redline shifts (on a racetrack -- I'm not crazy) from 2-3, 3-4, and 4-5, and it never had an issue. I think the problem is isolated to that synchro -- defect? Who knows. I'll be sure to watch out for any future problems. In any event, my plan is to break the transmission in for 1,200 miles, and then do a fluid swap/drain for some redline.
06-29-2016, 03:27 PM | #96 | |
Rep 5,381
Just curious: 1) Do you have any power modifications? 2) Do you routinely do high rpm 1-2 shifts? My 2016 M235 6MT only has 4K miles and the shifting feels completely fine. I can't say I often wind out 1st much though or slam a 1-2 shift. Maybe once a month I'll so do it, but nailing it in 2nd and grabbing a quick 2-3 shift is pretty normal. Hitting a 1-2 shift in any manual car has always felt a bit harsh. Apparently the 1-2 syncros are a bit pissy in these trannies. |
06-29-2016, 04:28 PM | #97 | |
Rep 845
Yeah, I know that these problems exist in most manual transmission cars -- they don't really like being slam shifted from 1 to 2 (unless its a honda tranny, I guess). I think its based on the fact that the gear ratio change from 1 to 2 is much greater than the change from 2 to 3, 3 to 4, etc, so the synchros have to do a lot more work, leading to failure. I'm not terribly worried about it. The car didn't always have this issue, so I don't think it is a design flaw -- something just broke is all.
06-29-2016, 05:34 PM | #98 |
Rep 1,117
good to hear it'll be sorted liquid!
07-01-2016, 12:05 PM | #99 |
Rep 845
Update:
Got my car back with the new gearbox. Problem is completely fixed, and it feels much, much better than it ever has. Gear shift feels like a well-oiled bolt-action rifle, no vagueness or rubberiness at all. Very confidence inspiring.
07-01-2016, 06:06 PM | #100 |
Rep 779
I know that feeling of freshly installed and/or adjusted manual gearbox. Give it a couple of months though and it will lose its tightness: apparently cars like Honda have "much better" transmission than our M135i/235i, see below:
07-01-2016, 06:11 PM | #101 | |
Rep 845
07-01-2016, 06:40 PM | #102 | |
Rep 1,117
08-05-2016, 02:25 PM | #103 |
Rep 199
Got mine back also. Shift much better than original.
08-05-2016, 07:02 PM | #104 |
Rep 5,381
After 6 months of fairly hard use, the 6mt in my 2016 m235 feels rock solid. The only change was that it's become easier to get into 2nd.
08-06-2016, 11:44 AM | #105 |
Rep 6
When the car was new I found the 6MT to be notchy and required some finesse on the 1 to 2 shift at moderate RPM's. Was worse still when cold. My solution was to go easy for the first 15 minutes or so and grinding was non existent. Now the car has close to 5 K on the odometer and while I still shift easy for the warm up period, the notchiness is gone and the shifts, even at higher RPM's are smooth all the time. Guess that the tranny needs a little break in time as well. Crunching it early in its life seems like the recipe for early tranny failures.
08-06-2016, 08:55 PM | #106 | |
Rep 892
The BMW shifter is slicker than American shifters under general conditions. I had a Hurst short-throw in the Mustang and it was precise like a rifle bolt action, but very high effort. The M235i shifter feels like butter in comparison. But the BMW shifter just feels like it could never take the abuse that a U.S. muscle car transmission can take. I'm not even going to take the chance and try it.
Previous: 2018 Camaro 2SS 1LE 6MT; 2015 BMW M235i 6MT; 2015 Mini Cooper F56 6MT; 2005 Mustang GT 5MT; 2003 Mini Cooper R50 5MT |
08-07-2016, 05:07 AM | #107 |
Rep 509
Drives: 2016 M235i RWD 6MT
I have read almost all the posts in this thread and recently picked up my M235i. June 2016 production and still in the break in period where I keep the RPMs lower than 4500k and driving it like a grandpa without hooning the engine. Why does it seem like there's a higher chance risk that the MT are experiencing either gearbox/transmission issues? I hope I am not the case... time to rack up more mileage on the car and pass the break in period and let her rip.
2015 ES350 6AT - Traded In 2004 RX330 5AT - Sold 2004 Civic Coupe Si(EX) 5MT - Retired 1993 Civic Coupe Si(EX) 5MT - Retired |
08-07-2016, 09:24 AM | #108 | |
Rep 1,117
Also, my old civic si did the same thing when I bought it used and I drove on it for like 120k. It never came to complete failure I would just have to do the 1-2 shift a bit slower at high rpm, otherwise it led to a nice audible grind during engagement. |
08-07-2016, 11:43 AM | #109 |
Rep 5,381
Yep, it's always good practice to let the gear box warm up before ripping on it. On a cold start, you could be looking at 5-10 minutes at least. The 1-2 syncro being the part with the most potential for damage.
I will say this about the 6MT, specifically the clutch, although the clutch pedal is fairly light and the overall clutch take-up quite long, the primary engagement point range is quite narrow. For me, a guy that has around 20 years of driving manuals under his belt, this car is somewhat difficult to get moving smoothly without concentrating and also on the 1-2 shift. I also find lower rpm rev matching hard to complete smoothly because the flywheel feels kind of heavy and the throttle pedal somewhat dead (even in Sport+) in the initial range of application. On many occasions when I'm on a decline or barely rolling, I'll just start in 2nd and then skip shift into 4th or 5th. During hard driving, the 6MT and clutch is money. The car is terribly easy for me to launch and manage wheel spin, I can bang the 1-2 and 2-3 shifts with ease (although I can feel the CDV and traction control at play on the 1-2, especially in Sport or Sport+), and rev match downshifts are easy. I guess you can't have it both ways. |
08-14-2016, 04:59 AM | #110 |
Rep 1
Hi Guys. I'm Mike from Johannesburg, South Africa. I drive a 2013 Manual M135i, apologies for crashing your 2 forum. I read this with great interest as my car is now going in again for the 2nd gearbox replacement and clutch replacement with exactly the same problem as few of you guys on this forum. I am very annoyed and disappointed, but don't have much choice except wait and see what happens with the new box. Again, apologies for gate crashing your 2 series forum with my 1 series issue I found this forum very helpful, and enlightening. So thanks Guys.
Drpoomanchu307.50 |
