10-15-2014, 10:26 AM | #23 | |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
10-15-2014, 01:47 PM | #24 | |
Rep 678
Anyone else go this route???
2022 M4 Comp X 2021 M440ix - Sold 2015 M235 - Sold |
10-15-2014, 06:08 PM | #26 |
Rep 678
That is the one I got, could not pass on that deal. Quality looks great, perfect fit and great results.
10-15-2014, 06:17 PM | #27 |
Rep 171
10-16-2014, 04:14 AM | #28 |
Rep 4,516
G Man - try map 5 - auto tune will give you more than map 1. I had custom map 6 on mine set up on a rolling road. LOL quick......PD
Current '22 X3M LCI.. |
10-16-2014, 03:18 PM | #29 | |
Rep 678
I did ask Burger which would be best and they suggested map2 would be more consistent and go with even higher octane if I want to use auto tune which was interesting. Still curious if anybody is doing the DP without EWG and FF running 93 on map 2???
10-16-2014, 03:29 PM | #30 | |
Rep 190,777
While map 5 sometime will target various boosts (higher or lower depending on your fuel and IAT) the only way you will know for sure which one works best for you is by trying each for a week at least.
10-17-2014, 05:12 AM | #32 |
Rep 4,516
G-man
I've run map 2 with 98RON fuel here in the UK w/o extra FF and EWG wires. No problems. Custom map 6 is like map 2 but with target boost settings established on a rolling road.....started the day with stock 320/330 power/torque at the crank and end up with 380/450 at the crank with map 6. Happy days.... PD.
10-17-2014, 09:30 AM | #33 | |
Rep 678
10-17-2014, 10:10 AM | #34 |
What goes here?
450
Rep 1,356
I was running very lean prior to installing the EWG/FF harnesses and this was on Terry's recommendation.
2019 G30 M550i
10-17-2014, 10:51 AM | #35 |
Rep 4,516
1st time I've read an issue of being too lean without EWG and FF wires.
Lots of posts out there already on assorted forums of folks having timing pulled and random boost overshotting targets with EWG wires only. BMS fixed it by firmware tweaks and advisory to install FF wires with EWG wires. I may consider it once BMS issue a new loom for EWG cars ie stage 2 plugs + integrated EWG harness and FF wires.
10-18-2014, 08:07 PM | #37 | |
Rep 678
I switched to map 2 and took a test drive and like map 1 it feels like stock if your just cruising but is a beast when you step on it. My only gripe was I was averaging 24.8 mpg before that test drive and it dropped to 24 after I will be getting some data logs on both maps to compare the two. Same for any other maps I run down the road.
10-21-2014, 12:59 PM | #38 |
Rep 678
Map 2 was a noticable improvement and once I get some data logs to confirm all is good is where I will stay and forego the EWG and FF.
Rolling back to map1 until I can find the time to get those logs. DP is definetly worth it, JB4 and DP is the way to go.
11-05-2014, 01:09 PM | #42 |
Rep 116
11-05-2014, 02:27 PM | #43 |
Rep 678
Great deal and enjoying your product. The customer service shipping and handeling were fantastic.
I'm back on map2 after capturing some logs and verifying all was looking good. I see my boost peaking at 13.9, not too shabby considering no EWG and FF and with everything looking good. Car is noticeably quicker. I'm pretty content at this point with the performance considering the time/money invested. Cat-Back would be nice if prices ever come down.
11-05-2014, 04:10 PM | #44 |
Rep 4,516
G-Man,
13.9 psi is good, I'm getting above 15psi on map6. Car runs fine, goes like stink and when cruising fuel economy is slightly better.
