2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning AT: Long pull left paddle to shift into lowest safe gear?
      10-04-2014, 09:45 AM   #1
haloeight
Drives: m235i xd perf. ed'n
How does this work / Is this working for anyone?
I can't seem to figure out how to get it to downshift into the lowest possible gear by long pulling as it says in the manual when in manual mode. Doing so just seem to shift down to the next sequential gear.
Seem to recall the CA saying that the 8AT wouldn't always shift down sequentially but that's what it seems to be doing from what I can see.
Thanks
      10-12-2014, 10:15 PM   #2
haloeight
Anyone? In the manual it says this:
Shift down into the lowest possible gear: pull and hold left shift paddle.
But doing so only seems to result in one sequential shift down, not any further.
      10-14-2014, 02:37 PM   #3
FlyingFinn
Finland
20
Pull and hold the paddle and floor the gas pedal. I didn't know about this feature. Thanks for the tip.
      10-14-2014, 05:32 PM   #4
haloeight
Thank you - I will give that a go as so far I think I'd just been pulling + holding when decelerating or not on the throttle.
      10-14-2014, 05:53 PM   #5
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Is this confrmed...anyone had it worked?
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      10-14-2014, 06:29 PM   #6
nzw212
Drives: M235XI, Maserati, Ducati
I tried the pull and hold today but no luck. I'll floor the gas tomorrow. Even if it doesn't work, it should be fun.
      10-14-2014, 06:30 PM   #7
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Ok, just becareful...do it on an open road
2006 325xi (Sold)
      10-14-2014, 07:18 PM   #8
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
it's much easier to just do kick down and will shift to the lowest gear with just using throttle
      10-14-2014, 08:47 PM   #9
G-Mann
G-Mann's Avatar
413
Drives: M4CX
I gave what the OP described a shot but did not get it to drop more than 1 gear but perhaps I was doing it wrong so I will try again. This was a good find, my only gripe with an auto is not being able to throw it into the gear I want
Pikcachu can you describe how to do a kick down.
2022 M4 Comp X
2021 M440ix - Sold
2015 M235 - Sold
      10-14-2014, 10:40 PM   #10
pikcachu
pikcachu's Avatar
1399
push the gas pass the ressistance point and you will feel a click
      10-15-2014, 12:42 AM   #11
BLK235iNJ
BLK235iNJ's Avatar
182
Drives: m235i,13MustangGT,84C10,99A8
I use the gas to downshift most of the time.
      10-15-2014, 01:14 AM   #12
FlyingFinn
Finland
20
Yes, but this works in manual mode as well.
      10-15-2014, 09:33 AM   #13
RedRocketM2
RedRocketM2's Avatar
Drives: 435ix Performance Edition
LOL... know your revs and snap the paddle more then once it will never let you select to low a gear
      10-15-2014, 07:57 PM   #14
haloeight
I'm not sure I understand that comment. My interest was that the manual said something, the CA said something, ostensibly paid for that something and am unclear on how it actually works. There are easier / more straightforward ways as you and others mention to gear down.
Tried your suggestion FlyingFinn - it does not seem to work if within the first 1/3-1/2 of the throttle pedal range. I did not mash the throttle to the floor as you suggested, so perhaps that is the deciding factor? Will have to test when I have some clear road to try it on. Hopefully that will help to identify the exact pattern to do this.
      10-15-2014, 08:05 PM   #15
horsepower_and_hounds
Drives: BMW
tried it today on the way home from work...could not get it to work in any of the modes......
      10-15-2014, 08:24 PM   #16
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
lol another misinform from bmw
2006 325xi (Sold)
      10-15-2014, 08:32 PM   #17
d00t
I tried it last night and if you do the hold and tap the gas pedal hard (not floor it) it will automatically shift down the the lowest gear it sees fit ONCE, but will not continue to shift down after. (i.e. if decelerating at, say, 2k rpm in 6th, hold the down shift and tap the gas pedal hard it might skip down to 3rd).
      10-15-2014, 08:38 PM   #18
haloeight
Thanks - Interesting re skipping down to 3rd from 6th. That would definitely be different than what I had been seeing (6th to 5th and stops).
      10-15-2014, 08:48 PM   #19
d00t
When I did it last night it did 5->3
      10-15-2014, 10:29 PM   #20
BLK235iNJ
BLK235iNJ's Avatar
182
I like using the gas pedal to do this. It will not put the car into manual mode. downshifts become controllable through the gas pedal (lowest gear) and upshifts remain automatic.
Fun for street I'm sure for track use you would want to leverage the paddles in manual.
      10-16-2014, 10:49 AM   #21
FlyingFinn
Finland
20
As Pikcachu said you have to press the gas pedal beyond the resistance point. So first shift the stick to left to M/S mode and do manual shift to get the transmission to manual mode. Then hold the left paddle and press gas pedal deep enough and you will get lowest possible gear almost instantly. Be ready to shift up with the right paddle or the car will hit the rev limiter. In automatic mode I think there would be no use for this because the car will select automatically lowest possible gear when pressing the pedal beyond kick down point. Oh, and as also said in this thread: Be careful, the car is a rocket ship... Well, it's also made for driving fast...
      10-16-2014, 12:30 PM   #22
haloeight
Thanks again for the clarification & details
