2Addicts | BMW 2-Series forum BIMMERPOST Universal Forums General BMW News and Cars Discussion What are some common problems in a E63
      02-15-2012, 07:09 PM   #1
KwlAznKid
KwlAznKid's Avatar
354
Drives: BMW/MERCEDES/PORSCHE
Hi Everyone!
I might be picking up a 645CI convertible this weekend 78K miles on it, smg.
What are some common problems I should watch out for? I'm going to take it to the dealership to get a PPI for sure but I just want to see what to keep my eye out for?
I'm very familiar with the e46 and e9x chasis but have never worked on an e63 before
thanks
jon
BMW E93 M3 / Mercedes Benz W209 CLK500
BMW E64 650I(sold) / BMW E92 328I(sold) / BMW E46 M3(sold) / BMW E92 335I(sold)
Porsche 996 911 C2(sold) / BMW E46 325CI(totaled)
      02-16-2012, 04:14 PM   #2
az34
az34's Avatar
Drives: 2009 z4sdrive35i 2008 x5 3.0i
try to get a 650 and stay away of smg.
      02-16-2012, 06:26 PM   #3
KwlAznKid
KwlAznKid's Avatar
354
any particular reason why for both those suggestions? i have a smg m3 and i love it
      02-17-2012, 03:02 PM   #4
az34
az34's Avatar
i dont know the year of your M3, but smg on e60 5 series includes the M5 and M6 had a lot of bad reviews. As for the engine on early 645 they get a lot of problems whit the engine block be sure to investigate before you buy.
      02-20-2012, 02:55 AM   #5
afcneal
Drives: 135i
Oil leaks, oil leaks and oil leaks!
Engine block and gearbox sump - latter is a cheap fix if done before gearbox fails!
(Water) Leaks into trunk can ruin the amplifier
Software issues with I-drive
Steering rack is weak and $3000+ to replace
The inner water pipe (inside the block) is a catastrophic failure, but fortunately veyr rare.
Get a warranty - all E63/64 (yours is an E64 BTW!) are expensive to maintain and fix. Good cars though!
www.bmwenthusiasts.co.uk
      04-18-2014, 11:55 PM   #6
Cynthia_Lopez
Drives: BMW E65
BMW N62 V8 Coolant Pipe Repair Kit
Hello,
I am writing to tell you about a new BREAKTHROUGH method for repairing a leaking Coolant Transfer Pipe in the BMW N62 V8 engine block using the BimmerFix Stint. The N62 V8 is a popular BMW engine that was used from 2002 thru 2010, in such fabulous vehicles as the BMW 735i, 740i, 745i, 750i & Li, 645Ci, 650i, 540i, 545i, 550i, and the X5 SUV.
Located deep inside of this BMW N62 engine is a Coolant Transfer Pipe, which carries antifreeze from the Water Pump to cooling chambers within the engine. However, the Front Seal on this Cooling Tube can fail in as little as 40,000 miles, and start leaking antifreeze from the engine block, through a weep hole in the Timing Chain Cover. When this happens, the car will lose antifreeze from the engine, and the engine will overheat.
In the past, this has been a very expensive repair because it required disassembly of the engine, in order to access the leaking Cooling Pipe Seal. The original method of replacing the crossover Coolant Transfer Pipe required the removal of the Timing Chain Cover. This repair could cost $6,000 or more at the BMW Dealer.
Then, an after-market Collapsible Coolant Pipe was developed to save time and money on this repair. This Collapsible Coolant Pipe method involves removing the Intake Manifold, cutting out the old Coolant Pipe and installing the after-market Collapsible Coolant Pipe. But even this method required many hours of shop labor and expensive parts and supplies. The repair bill for this method can still cost between $1,500.00 and $2,500.00 to remove the Intake Manifold, cut out the old Coolant Pipe and install the new Collapsible Coolant Pipe.
However, BimmerFix Products Co. has discovered a BREAKTHROUGH system to stop the leak! The BimmerFix method is much faster and less expensive than these old methods. This simple, yet durable and long lasting method inserts the BimmerFix Stint into the leaking crossover cooling tube, through the Timing Chain Cover. The thin aluminum sleeve creates a long lasting repair that is much easier and less expensive to install than the old repair methods.
The new BimmerFix Stint will stop the Coolant Pipe leak, and only requires the removal of the Water Pump. This new patent protected invention can save YOU or your customer’s time, hassle, and thousands of dollars. It works or your money back!
Save time and money! Take a look at www.BimmerFix.com.
Watch The Video! You will be glad you did!
Thanks for your time!
Tucson, Arizona, USA
