2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning M Performance Exhaust
      12-13-2014, 08:09 AM   #1
deanyoungson
United Kingdom
Drives: BMW M235i
Hi guys,
does anybody have an M Performance exhaust? If so can you please tell me if when you start up the car, if only the drivers side exhaust seems to emit sound/smoke?
I suspect the exhaust is set to only open one flap on startup, then open up both once the car is running?
Is there any way to set to open up both flaps if this is the case?
      12-13-2014, 08:24 AM   #2
horsepower_and_hounds
Drives: BMW
No I don't have one, yes it has a flapper, and yes you can rig it to stay open. Search the forum
      12-13-2014, 10:47 AM   #3
worktolivelife
Drives: Mine
Press sport mode before start up and both valves open, it effectively creates a straight through as opposed to re circulating the exhaust gases, where's the pleasure in being an Eco warrior . The sports exhaust in combination with the selected mode instead of recirculating gases twice by- passes gospel according to BMW emergency services veteran
      12-13-2014, 11:03 AM   #4
deanyoungson
United Kingdom
Drives: BMW M235i
Cheers guys.
How do you select sport mode before turning the car on though...?
      12-13-2014, 11:03 AM   #5
alz0rz
What goes here?
alz0rz's Avatar
450
Drives: 2019 G30 M550i
Don't think you can change driving mode prior to startup...
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
      12-13-2014, 11:07 AM   #6
worktolivelife
Drives: Mine
Press ignition button once (feet off pedals) car powers up change driving mode , press ignition button again start as normal (auto/manual)
You can actually hear flap valves doing something by switching between modes after 1st power up button press
      12-13-2014, 11:26 AM   #7
deanyoungson
United Kingdom
Drives: BMW M235i
Ill give it a go... cheers!
      12-13-2014, 12:09 PM   #8
overcoil
Drives: M235i 6spd
Will try - if it works - thanks for the tip - very cool!
      12-13-2014, 08:26 PM   #9
kd0t
You can also just unplug the cord that controls this as well. I left mine off
      12-13-2014, 08:45 PM   #10
MG 228i
Drives: Z4 m40i, 340i 6MT, i3S
On cold starts one valve will open even in sport mode
