12-12-2014, 07:38 PM | #1 |
Comrade
56
Rep 211
Drives: 15 M4 DCT
Anyone running ER FMIC, DP, CP and JB4 together?
Thinking about adding the intercooler, downpipe and charge pipe to my jb4. Anyone have experience with how easy these are to install and how much power one could expect? Just trying to get as much info as possible before i click the shopping cart. Thank you in advance for the info
15 M4 / 14 M235i-Sold / 09 E92 M3-Sold / 07 E92 335i-Sold
12-12-2014, 08:08 PM | #3 |
Rep 2,363
Yup I'm running these as well as an intake and axelback exhaust. Had them installed at a shop locally. Charge pipe and intercooler being together makes it an easier install because if the intercooler is in is in the way of the charge pipe.
Follow my builds:
12-13-2014, 07:57 AM | #4 | |
General
12909
Rep 18,682
1. JB4 - gives you about 40+ whp on Map 1 2. Chargepipe - gives you reliability and better boost delivery to the engine 3. Intercooler - gives you better air temp, which in result, constant power gain. Especially since you are in AZ, you will very much need it. 4. Downpipe - I put this as the hardest because you will need to crawl under the car. But if you have access to the lift, it is not as hard as the intercooler. Gain wise, about 20whp since it will let your turbo to spool faster.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com SPRING Sale!! 04/01 - 04/15 - Code: "SPRING2024" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
12-13-2014, 08:20 AM | #5 |
Comrade
56
Rep 211
Drives: 15 M4 DCT
Thank you guys! Mteele let me know how it goes, imsure it will be a couple weeks before i get around to it.
03-12-2015, 12:46 PM | #6 | |
Rep 190,575
Intercooler is average ( 4 / 10) Downpipes is not hard but it is very time consuming (7 / 10) You will gain the most power from the Jb4 ~40 whp Charge pipe will add reliability intercooler will keep your IAT low so you car is consistent and your JB4 can target higher boost resulting in more power Downpipe will add a nice exhaust tone + ~25 whp over the ~40whp added by JB4 stage 1 Here are couple dyno graphs with different setup
03-12-2015, 02:22 PM | #7 | ||
Rep 513
Without a lift you need to remove front bumper and intercooler. |
03-12-2015, 06:49 PM | #8 | |
Rep 1,084
The CP and FMIC are a little fiddly. The DP was really straightforward, pleasantly, surprisingly easy. I think I'm at ~400WHP with those mods (and 100oct, which I run all the time). |
