Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      10-04-2016, 09:27 AM   #1
F80Dreamer
Drives: 2016 M4
Charcoal Filter Purpose?
Tried to do a search to find the answer but couldn't find it...I did a light mod on my car this weekend (replaced stock filters with BMC drop ins, removal of charcoal filters). Really like the sound difference and the sound of the turbos...but not really sure what the role is of the charcoal filter? Just another added layer of protection to not let any particles through? I am assuming it was there for a good reason...
      10-04-2016, 09:31 AM   #2
SO17
SO17's Avatar
79
Drives: 2018 MY M4CP
Emissions. US (and possibly others) have them, UK cars don't.
      10-04-2016, 09:37 AM   #3
stevenc
Coming Soon
Drives: 2015 BMW M4 Alphine White MT
Absorb gas fumes. European cars dont have them since their emissions standards are different.
      10-04-2016, 07:40 PM   #4
SloTUrtle
Drives: 2017 M3
Removing this won't void any warranties will it??
      10-04-2016, 08:21 PM   #5
schnell1982
Drives: FAST
Its a North America emission part.
I have never heard of anyone having a warranty related issue.
It will not set a "check engine" light or alter the way the car performs.
Probably one of the first things everyone removes
      10-04-2016, 08:49 PM   #6
M4RAUDR
M4RAUDR's Avatar
Drives: 16 AY M4
Prevents back flow of exhaust fumes out of intake. Completely ridiculous feature - remove them promptly.
2016 AY M4 : SB Full Leather : HRE P104 20" x 9.5" Front / 11.5" Rear : Pirelli PZero Nero GT 255/30/20 Front / 305/25/20 Rear : CCBs : KW v3's : Active Autowerke Full Exhaust & DPs : ESS Silicon Charge Pipes : VF HEX Stage 2 : VF TCU : Status Gruppe Rear Diffuser : M-Perf Side Blades : M-Perf Front Lip : Reus Audio System : Painted Side Reflectors : Black Grill Surrounds : Black Side Markers
      10-05-2016, 08:01 AM   #7
CaryTheLabelGuy
CaryTheLabelGuy's Avatar
Drives: 2016 M4 ZCP
It is there to stop positive crankcase venilation, which is routed back into the intake, from venting to atmosphere. It's main job is to catch microscopic oil droplets and any fuel contamination that may have blown by the piston rings and into the crankcase (the main cause of oil contamination).
sna66512.00
      10-05-2016, 09:28 AM   #8
swifty
Drives: F80, Levante & Tesla 100D
So does this mean it's a good for the car or for emissions?
Does anyone have a link to the filters?
Current Bimmer: '16 F80 M3, '20 F87 M2c
Gone but never forgotten: '13 FO e92 M3, Swifts, volks/advan, Akra Evo, Kics R40
Past: Alpine white e46 323i, Jet Black e39 530, Saph Black e60 530, Space Grey N54 e92 335, Mineral White N55 e92 335
      10-05-2016, 09:43 AM   #9
CaryTheLabelGuy
Drives: 2016 M4 ZCP
Any oil (in this case, from the crankcase) in the combustion chamber is a bad thing for the engine in that oil present in the combustion chamber lowers the detonation threshold and enough of it can easily cause knock. Having crankcase venilation routed into the intakes means 99.999% of the crankcase venilation is going to make its way back into the combustion chambers to be burned (for emissions). Those charcoal filters are there to stop the .000001% that might make it to the atmosphere.
Using an Oil Catch Can eliminates the need to route PCV into the intakes. The charcoal filters are more of a hindrance to performance and are only there for the stock PCV setup.
Appreciate 10
      04-29-2017, 08:25 PM   #10
aboulfad
aboulfad's Avatar
Drives: 2015 M4 MG/SO
2015 BMW M4  [10.00]
We were discussing flashing Euro DME onto our US DME and the removal of "something" from the intake silencer, is part #2 & 4 in https://www.etkbmw.com/bmw/EN/search...M4/USA/13_1612 that you refer to as the "charcoal filter" and that you remove completely?
EDIT: I am referencing above the air filter element, the "charcoal filter" that is discussed in this thread and removed by some cannot be easily found in ETK.
      04-30-2017, 02:16 PM   #11
Celestion
Drives: '22 M3 Comp
To those that say UK/ECE don't have it, ETK shows them as installed parts, and if you search the m3 cutters site, they talk about replacing them and servicing/buying them... so unsure where people find information that says it is NOT installed outside of North America.
hmmm. Those look like the normal air filters that indeed should not be removed.
Here is a pic of my liners for comparison (part #s: 70553698, 70553739)
      04-30-2017, 02:20 PM   #12
Celestion
Drives: '22 M3 Comp
What I find odd is that the part numbers don't show up for me in etk or realoem. I also haven't been able to find any documentation about these filters, even in ISTA.
aboulfad1595.50
      04-30-2017, 02:23 PM   #13
aboulfad
aboulfad's Avatar
2015 BMW M4  [10.00]
Tx for your reply, now I am really confused! Btw your part nbs aren't BMWs, well at least can't find them in ETK Where were those parts you removed, was there something else in the intake silencer housing?
ISTA only list air filter elements, search air filter and you will get a repair/replace doc.
Here's what hakcar wrote which implies there's something else...
edit: oh, and the "air filter element" in the diagrams on realoem and etkbmw is the main filter, not the extremely thin fibrous filter that clips on to the (top?) housing of the actual panel. Running without the "air filter element" would indeed be pretty silly
      04-30-2017, 02:34 PM   #14
Celestion
Drives: '22 M3 Comp
Tx for your reply, now I am really confused! Btw your part nbs aren't BMWs, well at least can't find them in ETK so what part is being removed, please provide a link from ETK online. Where were those parts you removed, was there something else in the intake silencer housing?
Here is a link and pic of the non-optional air filter. It is housed in the same air box as the liner and sits just beneath it.
aboulfad1595.50
      04-30-2017, 02:38 PM   #15
aboulfad
aboulfad's Avatar
2015 BMW M4  [10.00]
Ok thats the part I've been talking about that now we all agree shouldn't be removed. I was confused thinking they were the same part while there's another part the ETK diagrams don't show or list... weird!
      04-30-2017, 02:44 PM   #16
Celestion
Drives: '22 M3 Comp
Ok thats the part I've been talking about that now we all agree shouldn't be removed. I may have been confused thinking they were the same part while it seems there's another part the ETK diagrams don't show or list...
Yep. I think our inability to explicitly find this carbon liner thingy in BMW's part catalog is strange. I have a hypothesis though. The liner clips into the top of the air box housing. Maybe the American housing comes with the part installed and the euro one simply comes without it.
Edit: theory confirmed...
Euro housing mass = 0.990kg
NA housing housing mass = 1.170kg
      04-30-2017, 03:11 PM   #17
aboulfad
aboulfad's Avatar
2015 BMW M4  [10.00]
Yep. I think our inability to explicitly find this carbon liner thingy in BMW's part catalog is strange. I have hypothesis though. The part clips into the top of the air box housing. Maybe the American housing comes with the part installed and the euro one simply comes without it.
Nice try, but you gotta use ETK desktop or online, not realoem ;-), both ECE/US left/right intake silencer housing is 1.4kgs/0.99kgs! I have ETK 04/2017. The P/N are the same so they cant have different configurations. Mystery continues for this elusive charcoal filter, I'll ask my dealer tomorrow !
      04-30-2017, 03:18 PM   #18
Celestion
Drives: '22 M3 Comp
Nice try, but you gotta use ETK desktop or online, not realoem ;-), both ECE/US left/right intake silencer housing is 1.4kgs/0.99kgs! I have ETK 04/2017. The P/N are the same so they cant have different configurations. Mystery continues, I'll ask my dealer tomorrow !
Hmm, I'm finding the same regional weight differences for the air intakes in ETK though.
NA - right air intake
Application list for the NA part number.
EU - right air intake
Application list for the EU part number.
Strangely, the NA P/N approved vehicle list contains only NA cars, but the EU P/N list allows for the EU part to be used in EU AND NA cars. This is super confusing lol!!
      04-30-2017, 03:27 PM   #19
aboulfad
aboulfad's Avatar
2015 BMW M4  [10.00]
You have there two P/N there are not consecutive and not belonging to one vehicle... (491, 268)
For an M4 F82 US and do the same for ECE:
- Left is : https://www.etkbmw.com/bmw/en/parts/...ht/13717846269
- Right is: https://www.etkbmw.com/bmw/en/parts/...ht/13717846268
      04-30-2017, 03:39 PM   #20
Celestion
Drives: '22 M3 Comp
That's correct. I'm comparing the weights of the "NA" and "EU" right air boxes. My guess is that the NA unit contains the carbon liner whereas the EU unit does not, hence my interest in each of their weights.
liner (0.095kg) + right "EU" airbox, presumably linerless (0.99kg) = 1.085 kg
"NA" airbox = 1.170kg
So the EU airbox with the liner weight added to it, is about equal to the NA airbox alone. This seems like a good approach to me. Maybe I'm not understanding something fundamental lol.
      04-30-2017, 03:45 PM   #21
CanAutM3
General
CanAutM3's Avatar
Drives: 2021 911 turbo
Seems like you're onto something here
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
      04-30-2017, 03:55 PM   #22
aboulfad
aboulfad's Avatar
2015 BMW M4  [10.00]
I think one of us isn't getting the other if you do that, do it for the same car in different markets, don't choose a right pn for an M4 GTS/M3 and then use M4 for left pn.
So choose 268/269 not 268/491, and then you'll see that ECE/US for the consecutive pn are the same weight.
Furthermore, 268/269 are 1.4/0.99, 491/492 are 1.55/1.170 so the new combo 491/492 seem to be a bit heavier but still the same on ECE cars.
f80post
